Not consistently syncing from remote device
Files from my local drive will copy and sync to remote device but not from remote to my local. At least not consistently. Sometimes one or two files will sync back but not more than that. Getting the “folder marker missing” message. This is happening on multiple folders, not just one. Any help would be appreciated. Running v23.2 on my local and 14.0 on the remote. OSX Monterey 12.6.3 on Local and 10.15.7 Catalina on remote.
“folder marker missing” means the folder isn’t present on disk any more, or not accessible. You should troubleshoot the root cause of that. It’s not a good sign.
Mystery solved. My destination drive was extremely low on space (which I hadn’t realized). Once I cleared out space, syncing resumed.
