Not Backing Up ~/Library
I’m on a Mac. I configured Syncthing to backup my home folder (/Users/kevin). It isn’t backing up /Users/kevin/Library. It is backing up most other folders in my home folder. Here’s my Ignore Patterns. What am I failing to see?
.bash_history
.bash_sessions
.cache
Library/Application Support/CloudPull
Library/Application Support/Firefox
Library/Application Support/LeapingBrain
Library/Application Support/Little Snitch
Library/Application Support/Google/Chrome
Library/Application Support/Syncthing/*.db
Library/Preferences/com.apple.Safari.*
Library/Caches
Library/Containers/com.docker.docker
Sync
temp
.DS_Store
.Spotlight-V100
.Trash
._*
*.*.swx
*.*.swp
Thanks!
Never mind. The sync peer was filtering Library. Moral of the story: Check both ends.
