Hi; I have all nodes disconected when im trying to sync frm outside.
When im in a local net works fine.
Please tell me what info do you need: TCPDUMP? TRACE?
Thanks
Thanks
Syncthing tries to set up port mapping via UPnP, if UPnP fails on both devices, and both are behind a NAT, they won’t be able to connect.
You can try setting up a fixed port forwarding on either of the networks and it should work. Though make sure it’s the same port on the router and on the machine.
Also, I assume global discovery is showing OK on both devices?
yes, i have port forwarder
it is the correct port?
discovery is setted
Im also gettin this msg hourly.
19:55:34: Error renewing UPnP port mapping for external port 21493 on device ‘SMC8014WG’ (192.168.0.1): AddPortMapping: 500 Internal Server Error
The public and private ports have to be exactly the same (as I said in my previous post). And I don’t know why your router returns a 500.
You can try and enable STTRACE=upnp environment variable, perhaps that will tell you more.
The output of the trace: http://pastebin.com/hPVD2h7J the device outside of the local network is net.
i hope that you could help.
Thnx
I suggest you disable UPnP and just setup port forwarding where public and private port is 22000. If you setup a different port, then make sure to change protocol listen address to that port.
ok, i will try that. Thnx
keep with out connect
Have you set up port forwarding as I suggested?
yes.
It doesn’t seem to be active? Also, make sure UPnP is off.
