I killed an instance + monitor than ran for another user in its own environment to edit his config.
I can ssh+mykey log into this remote machine and I “su the-other-user”. how can I do some -no-console to restart his instance then exit back to my account… cleanly? I tried syncthing & but ST go on loging to the screen even when I exit the other user account to mine. ps aux shows his 2 instances seems to run OK. If I exit ssh back to local then login again to remore, ps aux shows ? in the pts column. Normal ? Usually this user autostarts ST on login without a terminal
