Need advice on how to do this kind of sync
Machine A
Folder A Receive Only (can receive from machine a or smartphone a)
Folder B Send and Receive with Machine B
Folder C Send and Receive with Machine B
Machine B
Smartphone A
Folder A Send only
Folder B Receive either from Machine A or B
Folder C Receive either from Machine A or B
is this setup at all possible?
You’re describing a need for local sync? Im not sure thats what you mean.
Synching synchs to other instances / devices.
You can have a folder om Ma that syncs folders with one or many other machines.
If you really want sync on same machine - you could use rsync. I suppose you could also run 2 instances of synching on same Machine but Ive never tried that.
@jesperordrup i am synching from different machine not same machine
what do you mean a folder om Ma?
I think you need to re-read your initial post, there are some inconsitencies in your setup description. Feel free to edit it for corrections.
Ma - short for Machine a.
Well then its possible with Syncthing. On each folder you tell which machine you want to sync with.
@acolomb im guessing your referring to folder A? i know folder a on machine A and B states that it should only receive. My question is will can machine a give machine b the same content in the event that smartphone a isnt available?
so my scenario is
smartphone A sends updates to machine A’ Folder A
smartphone A now is offline
machine B now comes online
can machine A send updates to machine Bs Folder A? is there a way to do this?
I was referring to your machine B sharing with itself and machine A receiving from itself.
