Having a heck of a time.
Installed: SyncThing & NFS Server (only on primary) (So I can quickly transfer video footage) Mounted a drive /dev/sdb to /home/myself/2/extended /dev/sdb on /home/myself/2/extended type ext4 (rw,relatime)
If I drop a file using NFS into the /2/ folder, which is the root of the sync folder, the files show up just fine. If I drop files into /2/extended folder, shows zero files.
So basically, I can use a non-mounted local folder and it works. Syncs all the things. If I use the mounted folder, it does not work. Can’t figure out why.
myself@nfs01:~/2$ ls -la
total 36232
drwxr-xr-x 4 myself myself 4096 Jun 24 05:03 .
drwxr-xr-x 7 myself myself 4096 Jun 24 03:41 ..
drwxr-xr-x 2 myself myself 4096 Jun 24 03:41 .stfolder
-rw-rw-r-- 1 myself myself 14935840 Jul 8 2018 apple.m4a
drwxr-xr-x 2 root root 4096 Jun 24 04:43 extended
-rw-rw-r-- 1 myself myself 17044860 Apr 7 2019 lastbreath.mp3
-r-xr-xr-x 1 root 4294967294 5095937 Jun 7 04:09 test000.mp3
myself@nfs01:~/2$
