1.16.0-rc.2 on two Linux laptops works as expected on local wlan, but if one laptop is trying to connect remotely it only connects after about 20-30 minutes and throughput is slow, at 15-20kps, normally 1-2mbs over VDSL. (Mobile data connection is similar.)
Revert both laptops to 1.15.1 and connection time is around 30 seconds using the same remote location and setup. Speed is also as expected.
Upgrade to 1.16.0-rc.1 and all is good again. The issues seems to be with rc.2, possibly #7551.
Thereās no relevant change between 1.16.0-rc.1 and 1.16.0-rc.2 (thereās hardly any change at all, except a fix for a new web UI bug).
Just to be sure: You described downgrading and upgrading back to rc.1, not having problems. Have you also tried rc.2 again after downgrading and does the problem still occur?
If yes, what type of connection do you get on rc.2 with the problems? (Sharing a screenshot with the affected remote device expanded contains the relevant info).
@bt90 I think itās via quic. Iām trying to confirm. Using 1.15.1 on both sides is with TCP, but I think the delayed, slowed connection is quic if one side is rc.2. I have no access to the remote device overnight. More testing needed.
The connection delay for QUIC is nothing new. Just pointing out that itās already a tracked issue with an explanation why this might happen if stateful firewalls or certain NAT types are involved.
The current state of our UDP hole punching is that it works but the delay is a bit of a gamble. Without further knowledge how often OP tested this, the observed connection delay could just be bad luck and not related to the underlying performance degradation.
I seem to be unable to reproduce the long delay. Both sides, local and remote, are now on 1.16.0-rc.2 and are now connecting reliably and quickly (~30 secs). Although each time I test, the remote will only use relay-client TCP (IVP4).
The long delay connecting, reported in my first post, was definitely quic-server (IVP6) on remote laptop, using both VDSL and mobile data. For interest, I tested with wireguard VPN (Mullvad) on and off with no difference.
Can I force a QUIC connection instead of TCP for further tests?
You can disable relaying to get TCP+QUIC, and then debug why TCP doesnāt connect (port forwarding, firewalls, etc). As noted itās not totally unexpected that QUIC can take a while to get a connection in some NAT scenarios, but while you can troubleshoot that youād be much better served by fixing things so you can get a direct TCP connection running instead.
There are now two laptops (A and B) and a RPi3 in the mix, all running 1.16.0-rc3. All have relaying disabled. All in a mesh setup.
The Pi and A are connected via WLAN with local IPV4 addresses (192.168.etc). The Pi quickly connected to B via IVP6 addresses in a QUIC-client/server combination. B is using mobile data to simulate āremoteā WAN.
It took more than an hour for A and B to finally connect via IVP6 QUIC.
(Edit: the connection has now dropped between A and B, while the Pi - B combination seems stable.)
Firewalls (UFW) allow Syncthing traffic as mentioned in the docs.
Did the connection drop at the same time as the other was established? I guess Syncthing listens on and the connection is established at whatever port is āpunched openā. Once a conn is established, that port is occupied and for a second conn it would need to listen/punch a different port. Which it doesnāt, as it knows nothing about established conns.
Also this is all quite interesting to experiment with, but the practical problem (reliable connection) could be solved
What @bt90 plus to prevent a misunderstanding: Firewall is often interpreted as the program running on your computer, while the main thing to configure is the router/NAT (port forwarding).
