I seem to be having a problem syncthing two LAN computers together.
Both of them have the same Device IDs
Here’s a general idea of what i did.
1.) found syncthing
2.) downloaded it on pc#1, installed it.
3.) followed the step by step protocol
4.) opened pc#2 and downloaded syncthing, installed it.
(important note: I did not copy/paste any folder, file, or installer.)
5.) copied the device id on pc#2 and pasted it on the “add device” on
pc#1.
6.) problem arises. “A device with that ID is already added.”
7.) checked the device ID on both pc’s.
8.) they’re both the same.
I would like to know how to change the Device ID to make things much more simpler, i’ve been on the forums for almost two hours now and i haven’t found a solution to this problem, nor a question for it.
