i want some folders in my phone to upload only to desktop. i dont want to delete anything in the desktop folder if i delete something in my phone.
i tried to enable send only option in both side. but it shows out of sync.
There is an advanced ignore deletes option, but devices will forever look out of sync. It’s covered somewhere in the docs.
i found ignoreDelete option in advance menu. this seems to remove out of sync text and work perfectly for my purpose!
You should only set send only on the phones side. If you set it on the desktop the desktop should not receive changes made on the phone.
Hello! Could you explain in detail how did you do it? I’m a bit lost in here. Thanks!
in the desktop version of syncthing, go to advanced options, then the expand the folder options and tick ignoreDelete option.
Thank you so much!
