Is it possible to delete .stfolder and stignore file?
There’s no character restriction for folder IDs. However we could use a short hash of the folder ID, or base32 encode it, or something.
Doesn’t there already exist some kind of mechanism that is applied when folder IDs are used instead of labels for the root path? What I mean is that when “Auto Accept” is enabled, but a folder with the exact same name already exists in the path, then Syncthing uses the folder ID for the automatically accepted one, instead of its original label. I haven’t tested what happens if the ID is custom and uses funky characters though.
Yeah there’s a filter that creates a reasonable directory name from a folder ID or label, but that doesn’t result in something that’s provably unique.
(That said, if you wanted to share a directory both as abcd*^*1234 and abcd<:>1234 and complained that it resulted in the same on-disk folder ID representation of abcd_1234 then “don’t do that then” is close to hand.)
Our auto generated folder IDs don’t suffer from these ambiguities, you’d have to actively go looking for it.
It turns out that Syncthing is quite bulletproof :slightly_smiling_face:.
Auto Accept is enabled, but if automatically added, the folder would end up using the very same path as the existing one, so it actually asks what to do.
I actually like this one, because it keeps the root folder clean, with only one Syncthing-related folder there. Ignores (and versions) could also potentially be stored inside those, e.g. using .syncthing/.abcde-fghij/.stignore or something in this manner.
Here’s a visual of what’s been discussed, with a few of my ideas thrown in:
/!syncthing/ # not hidden, so user can easily find ignore files?
 + folde-rid01/ # replaces .stfolder, folder marker, not hidden
   + .versions/ # replaces /.stversions, file versions, hidden
   + .tmp/ # stores all temp files, per #2208, hidden
   + ignore.txt # replaces /.stignore, default ignore file, not hidden (user created, optional)
   + included.txt # included ignore files (user created, optional)
The !syncthing folder is named such, so it will stand out from other directories, and sort first in a listing. If we’d rather it sort last, we can name it ~syncthing.
But it bears asking: Do we want to allow different folders to share the same folder root, but with different ignore patterns? Unless the ignore patterns are mutually exclusive, will Syncthing play nice with itself handling concurrent folder changes in a single directory?
Ignore includes are relative to folder root, and probably should stay that way.
We should probably drop the folder- prefix as it serves no purpose.
We should not permit folder ids to be non [a-z0-9]. Folders have labels as the display value so there is no point having anything else than auto-generated values in the id.
I don’t think we can easily move the temp file creation location, it probably requires more thinking.
And yes, sharing the same folder root is an existing usecase, which could be improved by permitting separate ignores etc.
Isn’t it better to keep it hidden though? Normal users shouldn’t really be messing about inside those folders directly. The GUI offers control over both ignore patterns and versioning already, so I’m not sure if there is any actual need for keeping them visible. More advanced users, who need direct access, won’t have problems accessing hidden folders anyway.
On the other hand, if the top .syncthing folder is hidden, there’s not really any need to hide the subfolders, is it?
How about something more like this?
/.syncthing/ # hidden
   + versions/ # replaces /.stversions
   + tmp/ # stores all temp files, per #2208 <-- for consideration, implemented later
   + ignore.txt # replaces /stignore, default ignore file
However, there is also a problem with those, whose .stfolder is a file rather than a folder right now (although it could probably be automatically converted), and also those that use custom folder markers, which is a much bigger problem, because you cannot really store any Syncthing-related stuff there.
I’m not sure if there exists an issue on GitHub about this, but there have been some discussions in the forums for sure. There could be a variety of use cases for having different ignore patterns for the same root path, e.g. like my own in https://forum.syncthing.net/t/solved-large-index-size-with-nothing-synced-but-a-lot-of-ignores/14284. Also, they would be useful when sharing the same folder with different people without wanting to give them access to everything.
Syncthing can do this already :wink: (without different ignore patterns). You can add the same folder even 100 times, and it will work, with understandable performance impact, that is.
Backward compatibility will be a huge problem with this one, won’t it? There surely are some users with very funky custom folder IDs currently :confused:.
Moving ignore patterns into the config, perhaps retaining #include directives from there, would probably solve some concerns. You could even retain the legacy behavior if you wanted by having the in-config ignore patterns be just #include .stignore.
If folderId != strings.ToLower(SanitizePath(folderId)),1 we could use the base32 (or even a modified base41) of the folder id, and then include a file in .syncthing/, say folderid.txt, that contains the actual id, to allow multi-folder users to determine which is which.
Moving ignores to the config, while allowing to include other files, sounds very nice.
Regarding temp files I would not try moving those to a central location. There may be different file systems mounted underneath one Syncthing folder (even on Windows IIRC), so renaming the temp file to its final name will require another copy operation, which is not atomic. Keeping them right beside the target is the only sensible way I see here.
I’d vote for keeping the .syncthing folder hidden, as it it’s more an internal data store not relevant to most basic usage patterns.
The folder marker is configurable for a reason, namely to support read-only filesystems. The same should hold for the hypothetical .syncthing hierarchy IMHO. So everything in there should be optional as well. That’s definitely true for versioning, as that is even disabled by default. Or if it needs to go outside the folder, external versioning can be used for the special case. Changing the default location to .syncthing/versions/ sounds fine though.
If the ignores were stored in the config, the whole point of keeping several folder markers with different IDs becomes redundant. EDIT: Not really, if we want to solve the issue of detecting swapped USB disks…
Yeah, although frankly, if ignores are no longer the problem, we can also utilise the current custom folder marker option to solve the risk (of reusing the same path) already. On a similar vein, the versions path is also configurable right now, so it’s possible to place it even inside .stfolder, although I don’t think the path is relative to the root folder, so it likely needs to be absolute.
It would require more effort to physically move finished downloads to their proper location, although as far as I know/remember, other services like Dropbox do just that, so this may not necessary be a deal breaker (since it seems to have been working quite well for them).
The only sane way to move a file across fs boundaries is using a temp file, which brings us back to square one. I don’t really see temp file placement as being an issue though, in particular not the same issue as marker and ignore files.
