I want to add device via ip address, not device id.
is there any way get device id from ip address?
I tried to GET http://remote_ip:8384/rest/system/status
It returns timeout.
Please advice…
It returns timeout.
Please advice…
Timeout generally means firewall, in these circumstances. And also that Syncthing only listens on localhost by default.
Ok, then is it available that make syncthing listens from not only local but also remote(outside)?
This is all covered in the docs
Sorry I didn’t check the doc. I will check doc. Thank you so much.
