I have no idea, but I suspect the fault is at your end.
You can check config code for the types you should be using. I have no idea what their java equivalents are, but I guess string array makes sense.
I was just thinking along the same lines - incompatible types
Also, the fact that you are asked to restart syncthing when adding a folder or a device sounds like you’re also mis-serializing something else, as these actions do not require a restart.
If I knew GO better this would be simple - finding these in syncthing would be a challenge
Config code is, unsurprisingly, in lib/config package.
yes - I appreciate that it is well organized - I have looked into some of it
Also, if you don’t have 1 to 1 exact maching classes for the whole config, you are discarding fields when you are deserializing, and then posting the config back without those fields, you are implicitly un-setting them.
We discovered that early on
Well you haven’t discovered everything then I guess, as restart is only required by a handful of options, which you seem to have missed (Because you are getting the restart prompt).
I think your first assumption may be correct - I am looking at the go code and finding some issues with data types
