I wanted to connect a new instance to my syncthing network and have added a node but it remains Disconnected for some reason. When I expand the Remote Device, I can see the IP of the device it should get files from like: tcp://192.168.1.198:22000 that IP is accessible, nmap gives me:
Not shown: 995 filtered ports
PORT STATE SERVICE
22/tcp open ssh
53/tcp open domain
80/tcp open http
443/tcp open https
8080/tcp closed http-proxy
but trying to telnet on port 22000 doesn’t let me connect.
The node that cannot connect is a Ubuntu 18.04 VM that connects via NAT to my 192.168.1 network. Any suggestions to get this box connected too?
Filtered suggests its not open. Suggest you check that its running and listening on the roght port. Wven if the firewall is not “running”, I suggest you allow connections to that port.
