Installation problem
Hello,
I installed syncthing on 2 computers (windows) and 1 QNAP. I created all nodes on every computer and on qnap. I create a share folder with the same name on each computer All those are on the same local network
But none of the computers saw each other… They appear Disconnected
I don’t understand, could you please Help ?
Thanks
Go to folder settings and make sure you have selected all the devices that you want to share the folder with.
Hello,
Yes, in the folder settings, I have selected the device I want to share the folder with …
I followed the tuto : https://forum.syncthing.net/t/getting-started/46
But it doesn’t work…
Does it work if you enter the node ip addresses for each device rather than use auto discover?
No it does’nt work either with IP:port
for information, I installed this archive on my windows 8 PC: syncthing-windows-amd64-v0.10.11.zip
Perhaps some log file output would be helpful.
Hello,
Here is the log of my PC name “PORTABLE”
 [MMZH7] 22:49:47 INFO: syncthing v0.10.11 (go1.4rc2 windows-amd64 default) unknown-user@syncthing-builder 2014-12-08 12:25:27 UTC
[MMZH7] 22:49:47 INFO: My ID: MMZH7MD-QKQOEJQ-XDE6VIH-SOFNWYH-CZZOJ7T-EZW6QYW-55SL7CU-4ZMNRQ7
[MMZH7] 22:49:49 INFO: Starting web GUI on http://127.0.0.1:8080/
[MMZH7] 22:49:50 INFO: Starting UPnP discovery...
[MMZH7] 22:49:56 INFO: UPnP discovery complete (found 0 devices).
[MMZH7] 22:49:56 INFO: Starting local discovery announcements
[MMZH7] 22:49:56 INFO: Local discovery over IPv6 unavailable
[MMZH7] 22:49:56 INFO: Starting global discovery announcements
[MMZH7] 22:49:56 OK: Ready to synchronize Lightroom (read-write)
[MMZH7] 22:49:56 OK: Ready to synchronize default (read-write)
[MMZH7] 22:49:56 INFO: Device MMZH7MD-QKQOEJQ-XDE6VIH-SOFNWYH-CZZOJ7T-EZW6QYW-55SL7CU-4ZMNRQ7 is "PORTABLE" at [dynamic]
[MMZH7] 22:49:56 INFO: Device SCRM4Z6-OXBYYBV-D4JTFHS-3YUVNL5-5HOHPQL-B636TMW-HHRCOGV-WBUNNQZ is "QNAP-259" at [192.168.1.100:8090 dynamic]
[MMZH7] 22:49:56 INFO: Starting usage reporting
[MMZH7] 22:49:56 INFO: Connection from 192.168.1.100:8090 with unknown device ID 4I6YGK7-P4XRZHY-FWUODBG-YZWXN7M-6KT7EYG-4PBFE3P-55MOHTJ-WRHJTAN; ignoring
[MMZH7] 22:49:57 INFO: Completed initial scan (rw) of folder default
[MMZH7] 22:49:57 INFO: Completed initial scan (rw) of folder Lightroom
[MMZH7] 22:49:58 INFO: Connection from 192.168.1.100:8090 with unknown device ID 4I6YGK7-P4XRZHY-FWUODBG-YZWXN7M-6KT7EYG-4PBFE3P-55MOHTJ-WRHJTAN; ignoring
for information, 192.168.1.100:8090 is one of my IP, but the device ID 4I6YGK7-… does’nt match with none of my devices
It seems that you’ve not added or added the wrong device id on one of your nodes
the device ID of the device on 192.168.1.100:8090 is SCRM4Z6-OXBYYBV-D4JTFHS-3YUVNL5-5HOHPQL-B636TMW-HHRCOGV-WBUNNQZ and not 4I6YGK7-P4XRZHY-FWUODBG-YZWXN7M-6KT7EYG-4PBFE3P-55MOHTJ-WRHJTAN
I foud it by clinking on Config > show ID
is that correct ?
Well the log says otherwise.
I delete Syncthing on each PC ans I re install it from scratch. And it still doesnt work…
Here are the log of my “TOUR”:
    [YLB6B] 21:07:22 INFO: syncthing v0.10.12 (go1.4 windows-amd64 default) unknown-user@syncthing-builder 2014-12-16 22:33:56 UTC
[YLB6B] 21:07:22 INFO: My ID: YLB6BF7-KZZFFKR-3XJ3WHF-VTVZBP2-2AFLN6H-KPZH7FZ-GI5Q6MD-JBKIWAX
[YLB6B] 21:07:22 INFO: Starting web GUI on http://127.0.0.1:8080/
[YLB6B] 21:07:22 INFO: Starting UPnP discovery...
[YLB6B] 21:07:28 INFO: UPnP discovery complete (found 0 devices).
[YLB6B] 21:07:28 INFO: Starting local discovery announcements
[YLB6B] 21:07:28 INFO: Local discovery over IPv6 unavailable
[YLB6B] 21:07:28 INFO: Starting global discovery announcements
[YLB6B] 21:07:28 OK: Ready to synchronize default (read-write)
[YLB6B] 21:07:28 INFO: Device MMZH7MD-QKQOEJQ-XDE6VIH-SOFNWYH-CZZOJ7T-EZW6QYW-55SL7CU-4ZMNRQ7 is "PORTABLE" at [dynamic 192.168.1.29:8080]
[YLB6B] 21:07:28 INFO: Device YLB6BF7-KZZFFKR-3XJ3WHF-VTVZBP2-2AFLN6H-KPZH7FZ-GI5Q6MD-JBKIWAX is "TOUR" at [dynamic]
[YLB6B] 21:07:28 INFO: Starting usage reporting
[YLB6B] 21:07:28 INFO: Completed initial scan (rw) of folder default
And here are the log of my PORTABLE
[MMZH7] 21:17:32 INFO: syncthing v0.10.12 (go1.4 windows-amd64 default) unknown-user@syncthing-builder 2014-12-16 22:33:56 UTC
[MMZH7] 21:17:32 INFO: My ID: MMZH7MD-QKQOEJQ-XDE6VIH-SOFNWYH-CZZOJ7T-EZW6QYW-55SL7CU-4ZMNRQ7
[MMZH7] 21:17:32 INFO: Starting web GUI on http://127.0.0.1:8080/
[MMZH7] 21:17:33 INFO: Starting UPnP discovery...
[MMZH7] 21:17:39 INFO: UPnP discovery complete (found 0 devices).
[MMZH7] 21:17:39 INFO: Starting local discovery announcements
[MMZH7] 21:17:39 INFO: Local discovery over IPv6 unavailable
[MMZH7] 21:17:39 INFO: Starting global discovery announcements
[MMZH7] 21:17:39 OK: Ready to synchronize default (read-write)
[MMZH7] 21:17:39 INFO: Device MMZH7MD-QKQOEJQ-XDE6VIH-SOFNWYH-CZZOJ7T-EZW6QYW-55SL7CU-4ZMNRQ7 is "PORTABLE" at [dynamic]
[MMZH7] 21:17:39 INFO: Device YLB6BF7-KZZFFKR-3XJ3WHF-VTVZBP2-2AFLN6H-KPZH7FZ-GI5Q6MD-JBKIWAX is "TOUR-ASUS" at [dynamic 192.168.1.23:8080]
[MMZH7] 21:17:39 INFO: Starting usage reporting
[MMZH7] 21:17:39 INFO: Completed initial scan (rw) of folder default
Do you see someting wrong ?
I have got a strage connextion from my ip 192.168.1.23:8080
[MMZH7] 22:21:50 INFO: Connection from 192.168.1.23:8080 with unknown device ID BJFXKKY-S47CRC4-BM4ORO2-SIABDBT-HK4CY2A-FDQZTWU-MVKRAXM-U5JHOAG; ignoring
The device ID should be YLB6BF7-KZZFFKR-3XJ3WHF-VTVZBP2-2AFLN6H-KPZH7FZ-GI5Q6MD-JBKIWAX and not BJFXKKY-S47CRC4-BM4ORO2-SIABDBT-HK4CY2A-FDQZTWU-MVKRAXM-U5JHOAG
and the same appear on IP: 192.168.1.29:8080 it look like device ID is changing !
[YLB6B] 22:24:41 INFO: Connection from 192.168.1.29:8080 with unknown device ID BWCUABV-PMAX53Z-5ZRYJL7-A3EBIVH-BYYT3UK-MFLEZBW-T5HSVOD-KC36ZAU; ignoring
Strange !
You are configuring your devices to connect to port 8080. Port 8080 is the web GUI, which does have a certificate (and thus a device ID), but certainly not the expected one. You want port 22000, or simply leave the port blank.
Thanks it working with IP only (no port)
But, why does’nt it work with “dynamic” ??? Do I have to force IP ?? Because I am on DHCP on both of my computers ?
Not sure, it usually works fine. At a guess, firewall on your computers perhaps?
No, firewall are off (only for tests) and it does’nt change anyting…
