I am using v11.8 on Windows and I always get this:
[6TQJ3] 21:23:41 INFO: Puller (folder "Referendariat", dir "Englisch\\Projekt\\Making a Magazine in groups"): delete: <nil>
Yeah, the next version will have a bug fix which actually exposes the real error, rather than a nil.
Usually one of the potential causes for this is that some files which are still in the folder are ignored, preventing syncthing from removing the folder.
I am using v11.8 on Ubuntu and it keeps consuming extremely high amounts of CPU whilst throwing similar messages, then repetitively dies and re-spawns:
Jun 10 19:38:56 x syncthing: [XUUME] 19:38:56 INFO: Puller (folder "code", dir "js/bower_components/modernizr/test/caniuse_files"): delete: <nil>
Jun 10 19:38:56 x syncthing: panic: open /home/x/.config/syncthing/index-v0.11.0.db/101436.ldb: too many open files
....Go routines debug...
Jun 10 19:38:56 x kernel: [769308.457690] init: syncthing main process ended, respawning
Jun 10 19:38:56 x syncthing: [XUUME] 19:38:56 INFO: syncthing v0.11.8 (go1.4.2 linux-amd64 default) unknown-user@syncthing-builder 2015-06-07 10:57:26 UTC
Thanks @Zillode . I already had 1048576 max watches on the server where syncthing produced this log, so I guess it was actually complaining about the computer it was syncing from. It is not that clear to me from the error as both computers have the same syncthing config path that it mentions. Perhaps that error message could be improved to clarify which computer has too many open files.
I deleted the slave folder on the server causing the issues and increased the max watches on the other PC as you suggested. Then it appeared that I needed to reset the indexes before it could successfully sync again as it was showing âcluster out of syncâ and was not performing any actions even a while after I had clicked âoverrideâ.
On one device ST is trying to delete a folder which is not ment to be deleted and an all other devices the folder is also not deleted. I always get this:
[Y7IWD] 13:15:53 INFO: Puller (folder "Referendariat", dir "Pädagogik\\Fachsitzungen"): delete: <nil>
I have the same problem on Arm Linux on Android 11.8.
The weird thing is that I do not know why it is trying to delete the folder, because the folder it is complaning about has not changed in months on any of my devices.
Iâm having this problem on 64-bit OS X, syncthing version 11.9. Itâs for a folder that I deleted on another device a few days ago, when the whole cluster was on a different version. The deletion was propagated to the rest of the cluster but I just booted up the darwin machine and upgraded syncthing from 11.8 to 11.9 and now Iâm getting this error.
Did you rescan on the RPI?
You can get STTRACE=scanner trace and then http://docs.syncthing.net/rest/db-file-get.html (takes folder and file query arguments) for the file in question?
You can use the command, even if the file is not there. Make sure that file is relative to the folder root, on windows you do set "STTRACE=scanner" before launching syncthing.
Could you please give me an example on how to execute the sttrace and the âdb fileâ.
sttrace seems not an executable which I can use in windows. or do I have t execute this in connection with syncthing? Sorry for the stupid qeuestions
