Hi all,
I removed remote device recently, but it appears in device list again. Tried several times, no luck. How do I remove remote device permanently or add to some ignore list? Thanks ahead.
Hi all,
You have introducer enabled. Check the docs.
As far as I can understand, introducer allows to automatically add new directories on remote devices. How do I keep this option, but ignore just one device ID ? Please advice.
You can’t, as soon as you remove it, it will be reintroduced by someone. You either need to disable introducer or disable introducer, remove the device on all nodes and re-enable introducer.
