You can’t get the logs after the fact, you should run with -verbose -audit next time. Anyways, see if you can reproduce the issue, if you can, produce detailed step by step guide that reproduces the issue and we’ll look into it.
just tried it again and it did what I wanted. ( I don’t know wtf happened)
Do you see anything wrong with above steps I did ?
My goal was to sync some folders in my home dir that I use on all my laptops.
So my theory was add home dir ignore everything and add folders I want. ?
@AudriusButkevicius I am going to try again and see how I go, could you just let me know if steps above I mentioned are ok ? Would you do it differently?
They look ok, I wouldn’t expect them to cause issues.
