I’m trying to figure out how to change the root node of my chain to an untrusted node in the cloud. What would the best way to do that be and how do find the encryption keys to be able to connect the other nodes to it?
Just a generic comment, but you really should provide more information (detailed description, screenshots of the Web GUI, etc.) that would, so to say, “help others help you” .
Otherwise, it’s very difficult to guess what you mean exactly with so little info.
