I am really struggling to sort out out of sync stuff
I have a remote server which I sync with unraid the remote server sends only and the local server syncs with it but because I delete folders due to some are moved to another location on my server I have 2 terrabytes out of sync. I looked at ignoring any from a certain date but saw you can’t do this so decided to build the .stignore file manually by adding all the old files but for some reason no matter how many times I can’t get all the files to be ignored. I still have 643 GiB out of sync is there a way to just ignore everything or any other workarounds as it s getting very annoying. Thanks I now think it is related to this for some reason my remote server wont connect with my local server and I can’t understand why
It’s been more than 5 months since “seedbox” was last seen by whichever device the screenshot is from (is “seedbox” the UnRAID server>).
Diagnosing network connectivity issues is difficult without enough information. You’ll need to provide as much detail as possible.
With regards to working with ignore patterns, what’s your in your current .stignore file?
Worked it out the hoster of the server changed the listening port. All good now
