I got redirected here from the github issue page (because apparently stuck plain synchronization is not a bug).
This message will be cut into several parts, because new users are not allowed to put attachments and files to posts.
– PART 1 —
When I first run of the syncthing, everything got synchronized. But after deleting the share on one end and re-adding, the synchronization got stuck on 100%. After some changes to the files and resetting the deltas and database, the synchronization got stuck somewhere around 74%. Then, after another reset - it got stuck on 34% and then, finally, on 0%. On the other end, the syncthing was always stuck at 0%.
All the logs are produced with (syncthing -verbose -reset-deltas -no-browser
) after reseting the database. I paste the abbreviated versions of the logs inline. Full logs are in attachments.
adam-gs40:
[monitor] 09:28:41 INFO: Starting syncthing
[UAFG3] 09:28:41 INFO: syncthing v0.14.30 "Dysprosium Dragonfly" (go1.8.3 linux-amd64) deb@build.syncthing.net 2017-05-31 18:14:04 UTC [noupgrade]
[UAFG3] 09:28:41 INFO: My ID: UAFG3PX-XII5PN4-F3SIVBO-KVFCCNX-LHJWS7F-37D7BSM-P6VSL33-XHGO6QA
[UAFG3] 09:28:42 INFO: Single thread SHA256 performance is 314 MB/s using minio/sha256-simd (275 MB/s using crypto/sha256).
[UAFG3] 09:28:42 INFO: Hashing performance with weak hash is 264.76 MB/s
[UAFG3] 09:28:43 INFO: Hashing performance without weak hash is 316.37 MB/s
[UAFG3] 09:28:43 VERBOSE: Starting up (/home/adam/.config/syncthing)
[UAFG3] 09:28:43 INFO: Weak hash enabled, as it has an acceptable performance impact.
[UAFG3] 09:28:43 INFO: Reinitializing delta index IDs
[UAFG3] 09:28:43 INFO: Ready to synchronize "Default Folder" (default) (readwrite)
[UAFG3] 09:28:43 INFO: Ready to synchronize "Shared files" (hrqcl-ad5f9) (readwrite)
[UAFG3] 09:28:43 INFO: Ready to synchronize "raportyAR" (ge3x2-vzytz) (readwrite)
[UAFG3] 09:28:43 INFO: Send rate is unlimited, receive rate is unlimited
[UAFG3] 09:28:43 INFO: Rate limits do not apply to LAN connections
[UAFG3] 09:28:43 INFO: Using discovery server https://discovery-v4-2.syncthing.net/v2/?id=DVU36WY-H3LVZHW-E6LLFRE-YAFN5EL-HILWRYP-OC2M47J-Z4PE62Y-ADIBDQC
[UAFG3] 09:28:43 INFO: Using discovery server https://discovery-v4-3.syncthing.net/v2/?id=VK6HNJ3-VVMM66S-HRVWSCR-IXEHL2H-U4AQ4MW-UCPQBWX-J2L2UBK-NVZRDQZ
[UAFG3] 09:28:43 INFO: TCP listener ([::]:22000) starting
[UAFG3] 09:28:43 VERBOSE: Folder "default" is now scanning
[UAFG3] 09:28:43 VERBOSE: Folder "hrqcl-ad5f9" is now scanning
[UAFG3] 09:28:43 VERBOSE: Folder "ge3x2-vzytz" is now scanning
[UAFG3] 09:28:43 INFO: Completed initial scan (rw) of "Default Folder" (default)
[UAFG3] 09:28:43 VERBOSE: Folder "default" is now idle
[UAFG3] 09:28:43 VERBOSE: Local change detected in folder "hrqcl-ad5f9": added file /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/shared/Zamiany_zmiennych.ods
[UAFG3] 09:28:43 VERBOSE: Local change detected in folder "hrqcl-ad5f9": added file /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/shared/kodowanieEC.xlsx
[UAFG3] 09:28:43 VERBOSE: Local change detected in folder "hrqcl-ad5f9": added file /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/shared/macierze_analiz.ods
[UAFG3] 09:28:43 INFO: Completed initial scan (rw) of "Shared files" (hrqcl-ad5f9)
[UAFG3] 09:28:43 VERBOSE: Folder "hrqcl-ad5f9" is now idle
[UAFG3] 09:28:43 VERBOSE: Local change detected in folder "ge3x2-vzytz": added dir /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/raporty/boxplot
[UAFG3] 09:28:43 VERBOSE: Local change detected in folder "ge3x2-vzytz": added dir /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/raporty/boxplot_wyliczany
[UAFG3] 09:28:43 VERBOSE: Local change detected in folder "ge3x2-vzytz": added dir /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/raporty/crosstab
[UAFG3] 09:28:43 VERBOSE: Local change detected in folder "ge3x2-vzytz": added dir /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/raporty/hexplot
[UAFG3] 09:28:43 VERBOSE: Local change detected in folder "ge3x2-vzytz": added file /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/raporty/boxplot/0178_boxplot f_age × cong_dis_0907; gr sex filtr_dzieci_zywe.png
[UAFG3] 09:28:44 VERBOSE: Local change detected in folder "ge3x2-vzytz": added file /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/raporty/macierze_analiz.sync-conflict-20170615-152436-UAFG3PX.ods
[UAFG3] 09:28:44 VERBOSE: Local change detected in folder "ge3x2-vzytz": added file /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/raporty/process_one_png.sh
[UAFG3] 09:28:44 VERBOSE: Local change detected in folder "ge3x2-vzytz": added file /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/raporty/process_all_png.sh
[UAFG3] 09:28:44 INFO: Completed initial scan (rw) of "raportyAR" (ge3x2-vzytz)
[UAFG3] 09:28:44 VERBOSE: Folder "ge3x2-vzytz" is now idle
[UAFG3] 09:28:48 INFO: Using discovery server https://discovery-v4-4.syncthing.net/v2/?id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
[UAFG3] 09:28:48 INFO: Using discovery server https://discovery-v6-2.syncthing.net/v2/?id=DVU36WY-H3LVZHW-E6LLFRE-YAFN5EL-HILWRYP-OC2M47J-Z4PE62Y-ADIBDQC
[UAFG3] 09:28:48 INFO: Using discovery server https://discovery-v6-3.syncthing.net/v2/?id=VK6HNJ3-VVMM66S-HRVWSCR-IXEHL2H-U4AQ4MW-UCPQBWX-J2L2UBK-NVZRDQZ
[UAFG3] 09:28:48 INFO: Using discovery server https://discovery-v6-4.syncthing.net/v2/?id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
[UAFG3] 09:28:48 INFO: Device ZBWTUVT-KLK66IA-SDFWX5J-HHYRRC7-2LOYMGW-UJL7T4Z-CQKEE2O-LVNCKQZ is "T400" at [dynamic]
[UAFG3] 09:28:48 INFO: Device 5T2264T-CPK3UAY-7Q52INH-X6LMGCI-SP5GKBD-GBHO64W-NWDGWGM-GBQYXAU is "adam-miniPC" at [tcp://192.168.10.2:22000]
[UAFG3] 09:28:48 INFO: Device UAFG3PX-XII5PN4-F3SIVBO-KVFCCNX-LHJWS7F-37D7BSM-P6VSL33-XHGO6QA is "adam-gs40" at [dynamic]
[UAFG3] 09:28:48 INFO: Starting usage reporting
[UAFG3] 09:28:48 VERBOSE: Startup complete
[UAFG3] 09:28:48 INFO: GUI and API listening on 127.0.0.1:8384
[UAFG3] 09:28:48 INFO: Access the GUI via the following URL: http://127.0.0.1:8384/
[UAFG3] 09:28:48 INFO: Established secure connection to 5T2264T-CPK3UAY-7Q52INH-X6LMGCI-SP5GKBD-GBHO64W-NWDGWGM-GBQYXAU at 192.168.8.144:55860-192.168.10.2:22000 (tcp-client) (TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305)
[UAFG3] 09:28:48 INFO: Device 5T2264T-CPK3UAY-7Q52INH-X6LMGCI-SP5GKBD-GBHO64W-NWDGWGM-GBQYXAU client is "syncthing v0.14.30" named "adam-miniPC"
[UAFG3] 09:28:48 VERBOSE: Connected to device 5T2264T-CPK3UAY-7Q52INH-X6LMGCI-SP5GKBD-GBHO64W-NWDGWGM-GBQYXAU at 192.168.10.2:22000 (type tcp-client)
[UAFG3] 09:28:48 INFO: Ignoring folder "raportyAR" (ge3x2-vzytz) from device 5T2264T-CPK3UAY-7Q52INH-X6LMGCI-SP5GKBD-GBHO64W-NWDGWGM-GBQYXAU since we are configured to
[UAFG3] 09:28:48 INFO: Device 5T2264T-CPK3UAY-7Q52INH-X6LMGCI-SP5GKBD-GBHO64W-NWDGWGM-GBQYXAU folder "Shared files" (hrqcl-ad5f9) has a new index ID (0x57E4B077E5B87C93)
[UAFG3] 09:28:48 VERBOSE: Device 5T2264T-CPK3UAY-7Q52INH-X6LMGCI-SP5GKBD-GBHO64W-NWDGWGM-GBQYXAU sent an index update for "hrqcl-ad5f9" with 3 items
[UAFG3] 09:28:48 VERBOSE: Folder "hrqcl-ad5f9" is now syncing
[UAFG3] 09:28:48 VERBOSE: Folder "hrqcl-ad5f9" is now idle
[UAFG3] 09:28:48 VERBOSE: Summary for folder "hrqcl-ad5f9" is map[localFiles:3 localBytes:48079 needDirectories:0 needDeletes:0 inSyncFiles:3 localDirectories:0 version:6 localDeleted:0 inSyncBytes:48079 globalSymlinks:0 globalFiles:3 globalDirectories:0 needBytes:0 state:idle needFiles:0 localSymlinks:0 globalBytes:48079 sequence:6 globalDeleted:0 needSymlinks:0]
[UAFG3] 09:28:48 VERBOSE: Completion for folder "hrqcl-ad5f9" on device 5T2264T-CPK3UAY-7Q52INH-X6LMGCI-SP5GKBD-GBHO64W-NWDGWGM-GBQYXAU is 0%
[UAFG3] 09:28:48 VERBOSE: Device 5T2264T-CPK3UAY-7Q52INH-X6LMGCI-SP5GKBD-GBHO64W-NWDGWGM-GBQYXAU sent an index update for "ge3x2-vzytz" with 1000 items
[UAFG3] 09:28:48 VERBOSE: Folder "ge3x2-vzytz" is now syncing
[UAFG3] 09:28:48 VERBOSE: Started syncing "ge3x2-vzytz" / "boxplot_wyliczany" (update dir)
[UAFG3] 09:28:48 VERBOSE: Finished syncing "ge3x2-vzytz" / "boxplot_wyliczany" (update dir): Success
[UAFG3] 09:28:48 VERBOSE: Started syncing "ge3x2-vzytz" / "crosstab" (update dir)
[UAFG3] 09:28:48 VERBOSE: Finished syncing "ge3x2-vzytz" / "crosstab" (update dir): Success
[UAFG3] 09:28:48 VERBOSE: Started syncing "ge3x2-vzytz" / "hexplot" (update dir)
[UAFG3] 09:28:48 VERBOSE: Finished syncing "ge3x2-vzytz" / "hexplot" (update dir): Success
[UAFG3] 09:28:48 VERBOSE: Remote change detected in folder "ge3x2-vzytz": added dir /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/raporty/boxplot_wyliczany
[UAFG3] 09:28:48 VERBOSE: Remote change detected in folder "ge3x2-vzytz": added dir /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/raporty/crosstab
[UAFG3] 09:28:48 VERBOSE: Remote change detected in folder "ge3x2-vzytz": added dir /home/adam/Documents/Statystyka/Aktywne analizy/Yu Xia/yuxia/raporty/hexplot
[UAFG3] 09:28:48 VERBOSE: Device 5T2264T-CPK3UAY-7Q52INH-X6LMGCI-SP5GKBD-GBHO64W-NWDGWGM-GBQYXAU sent an index update for "ge3x2-vzytz" with 548 items
[UAFG3] 09:28:48 VERBOSE: Folder "ge3x2-vzytz" is now idle
[UAFG3] 09:28:48 VERBOSE: Summary for folder "ge3x2-vzytz" is map[needSymlinks:0 globalDeleted:0 globalFiles:3324 localBytes:458310438 needFiles:0 localSymlinks:0 inSyncBytes:458310438 localDirectories:4 sequence:5879 globalBytes:458310438 localFiles:3324 state:syncing localDeleted:0 needBytes:0 version:5879 globalDirectories:4 globalSymlinks:0 needDirectories:0 needDeletes:0 inSyncFiles:3324]
[UAFG3] 09:28:48 VERBOSE: Completion for folder "ge3x2-vzytz" on device 5T2264T-CPK3UAY-7Q52INH-X6LMGCI-SP5GKBD-GBHO64W-NWDGWGM-GBQYXAU is 8.378600357961119e-05%
[UAFG3] 09:28:50 VERBOSE: Summary for folder "hrqcl-ad5f9" is map[needBytes:0 localBytes:48079 needSymlinks:0 needDeletes:0 version:9 globalBytes:48079 inSyncFiles:3 globalDirectories:0 globalSymlinks:0 state:idle globalFiles:3 needDirectories:0 sequence:9 localDeleted:0 needFiles:0 localDirectories:0 localSymlinks:0 inSyncBytes:48079 localFiles:3 globalDeleted:0]
[UAFG3] 09:28:50 VERBOSE: Completion for folder "hrqcl-ad5f9" on device 5T2264T-CPK3UAY-7Q52INH-X6LMGCI-SP5GKBD-GBHO64W-NWDGWGM-GBQYXAU is 100%
[UAFG3] 09:28:54 INFO: New NAT port mapping: external TCP address 192.168.10.10:61870 to local address 0.0.0.0:22000.
[UAFG3] 09:28:54 INFO: New NAT port mapping: external TCP address 192.168.10.10:20641 to local address 0.0.0.0:22000.
[UAFG3] 09:28:54 INFO: Detected 2 NAT devices
[UAFG3] 09:28:54 VERBOSE: Listen address tcp://0.0.0.0:22000 resolution has changed: lan addresses: [tcp://0.0.0.0:22000] wan addresses: [tcp://0.0.0.0:22000 tcp://0.0.0.0:61870 tcp://0.0.0.0:61870 tcp://0.0.0.0:20641 tcp://0.0.0.0:20641]
[UAFG3] 09:29:23 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://178.32.221.151:22067/?id=DQTVSC2-GVNRCVJ-BM3YNZF-QJS5QM5-4JID3CM-HNLWYIZ-SYKTODV-PDX4ZAE&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=1000000&statusAddr=:22070&providedBy=fhransuski-lacznik] wan addresses: [relay://178.32.221.151:22067/?id=DQTVSC2-GVNRCVJ-BM3YNZF-QJS5QM5-4JID3CM-HNLWYIZ-SYKTODV-PDX4ZAE&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=1000000&statusAddr=:22070&providedBy=fhransuski-lacznik]
[UAFG3] 09:29:28 INFO: Could not connect to relay relay://178.32.221.151:22067/?id=DQTVSC2-GVNRCVJ-BM3YNZF-QJS5QM5-4JID3CM-HNLWYIZ-SYKTODV-PDX4ZAE&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=1000000&statusAddr=:22070&providedBy=fhransuski-lacznik: read tcp 192.168.8.144:43774->178.32.221.151:22067: i/o timeout
[UAFG3] 09:29:29 VERBOSE: Folder "ge3x2-vzytz" is now scanning
[UAFG3] 09:29:29 VERBOSE: Folder "ge3x2-vzytz" is now idle
[UAFG3] 09:29:33 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://213.239.217.18:22067/?id=COGM5LT-SJS25BV-XNK2WOX-7CFO56V-NFISVTI-4H2LF2U-DPCFOFP-KLEXUAF&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=spaam] wan addresses: [relay://213.239.217.18:22067/?id=COGM5LT-SJS25BV-XNK2WOX-7CFO56V-NFISVTI-4H2LF2U-DPCFOFP-KLEXUAF&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=spaam]
[UAFG3] 09:29:39 INFO: Could not connect to relay relay://213.239.217.18:22067/?id=COGM5LT-SJS25BV-XNK2WOX-7CFO56V-NFISVTI-4H2LF2U-DPCFOFP-KLEXUAF&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=spaam: read tcp 192.168.8.144:44092->213.239.217.18:22067: i/o timeout
[UAFG3] 09:29:40 VERBOSE: Folder "hrqcl-ad5f9" is now scanning
[UAFG3] 09:29:40 VERBOSE: Folder "hrqcl-ad5f9" is now idle
[UAFG3] 09:29:43 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://185.147.34.123:22067/?id=HJ6URI4-LFCU6HM-XEAVSIY-D52QRAR-CHOGYU3-DGDSRKJ-KUXASPT-FKCCMAB&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=InstallGentoo Syncthing Relay] wan addresses: [relay://185.147.34.123:22067/?id=HJ6URI4-LFCU6HM-XEAVSIY-D52QRAR-CHOGYU3-DGDSRKJ-KUXASPT-FKCCMAB&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=InstallGentoo Syncthing Relay]
[UAFG3] 09:29:49 INFO: Could not connect to relay relay://185.147.34.123:22067/?id=HJ6URI4-LFCU6HM-XEAVSIY-D52QRAR-CHOGYU3-DGDSRKJ-KUXASPT-FKCCMAB&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=InstallGentoo Syncthing Relay: read tcp 192.168.8.144:39674->185.147.34.123:22067: i/o timeout
[UAFG3] 09:29:52 VERBOSE: Folder "default" is now scanning
[UAFG3] 09:29:52 VERBOSE: Folder "default" is now idle
[UAFG3] 09:29:53 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://132.252.96.164:22067/?id=TDEWHQ6-5Y5IIAK-J7RV5JU-ZAFBI2R-6ICW5GP-M5PTAAF-H5Y2UIH-ENVUQAR&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=1048580&statusAddr=:22070&providedBy=inDane] wan addresses: [relay://132.252.96.164:22067/?id=TDEWHQ6-5Y5IIAK-J7RV5JU-ZAFBI2R-6ICW5GP-M5PTAAF-H5Y2UIH-ENVUQAR&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=1048580&statusAddr=:22070&providedBy=inDane]
[UAFG3] 09:29:59 INFO: Could not connect to relay relay://132.252.96.164:22067/?id=TDEWHQ6-5Y5IIAK-J7RV5JU-ZAFBI2R-6ICW5GP-M5PTAAF-H5Y2UIH-ENVUQAR&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=1048580&statusAddr=:22070&providedBy=inDane: read tcp 192.168.8.144:48190->132.252.96.164:22067: i/o timeout
[UAFG3] 09:30:03 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://37.139.13.201:443/?id=XP5SIGA-QZNLY3K-DCH2GUL-SEPITP6-W4G35B3-RQTYWRK-ZYJCBNA-YIIV5AV&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=] wan addresses: [relay://37.139.13.201:443/?id=XP5SIGA-QZNLY3K-DCH2GUL-SEPITP6-W4G35B3-RQTYWRK-ZYJCBNA-YIIV5AV&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=]
[UAFG3] 09:30:09 INFO: Could not connect to relay relay://37.139.13.201:443/?id=XP5SIGA-QZNLY3K-DCH2GUL-SEPITP6-W4G35B3-RQTYWRK-ZYJCBNA-YIIV5AV&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=: read tcp 192.168.8.144:56336->37.139.13.201:443: i/o timeout
[UAFG3] 09:30:13 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://62.210.142.39:22067/?id=M4VET5I-N4L7TRF-LMCP2CS-LL4M6IC-KPIBCZG-HX2BPKQ-OLTXJPD-RJYP4AL&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22068&providedBy=linuxthefish4 - Paris (8th arrondissement of Paris), FR] wan addresses: [relay://62.210.142.39:22067/?id=M4VET5I-N4L7TRF-LMCP2CS-LL4M6IC-KPIBCZG-HX2BPKQ-OLTXJPD-RJYP4AL&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22068&providedBy=linuxthefish4 - Paris (8th arrondissement of Paris), FR]
[UAFG3] 09:30:20 INFO: Could not connect to relay relay://62.210.142.39:22067/?id=M4VET5I-N4L7TRF-LMCP2CS-LL4M6IC-KPIBCZG-HX2BPKQ-OLTXJPD-RJYP4AL&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22068&providedBy=linuxthefish4 - Paris (8th arrondissement of Paris), FR: read tcp 192.168.8.144:42394->62.210.142.39:22067: i/o timeout
[UAFG3] 09:30:23 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://79.137.32.223:22067/?id=3YHK6UF-MVRQEJ4-Z3RA6L2-WJBDHHB-GPWQKS7-LHEAHI4-R7WDL4U-LRRAQQB&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=] wan addresses: [relay://79.137.32.223:22067/?id=3YHK6UF-MVRQEJ4-Z3RA6L2-WJBDHHB-GPWQKS7-LHEAHI4-R7WDL4U-LRRAQQB&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=]
[UAFG3] 09:30:30 INFO: Could not connect to relay relay://79.137.32.223:22067/?id=3YHK6UF-MVRQEJ4-Z3RA6L2-WJBDHHB-GPWQKS7-LHEAHI4-R7WDL4U-LRRAQQB&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=: read tcp 192.168.8.144:45616->79.137.32.223:22067: i/o timeout
[UAFG3] 09:30:32 VERBOSE: Folder "ge3x2-vzytz" is now scanning
[UAFG3] 09:30:32 VERBOSE: Folder "ge3x2-vzytz" is now idle
[UAFG3] 09:30:33 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://31.220.45.3:22067/?id=OHWS367-33NI2O3-GRQQVWG-6SHK655-ETRIJCC-GYTLNCT-2CBUXX5-XFFHCQ4&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=https://blog.veloc1ty.de] wan addresses: [relay://31.220.45.3:22067/?id=OHWS367-33NI2O3-GRQQVWG-6SHK655-ETRIJCC-GYTLNCT-2CBUXX5-XFFHCQ4&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=https://blog.veloc1ty.de]
[UAFG3] 09:30:40 INFO: Could not connect to relay relay://31.220.45.3:22067/?id=OHWS367-33NI2O3-GRQQVWG-6SHK655-ETRIJCC-GYTLNCT-2CBUXX5-XFFHCQ4&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=https://blog.veloc1ty.de: read tcp 192.168.8.144:34968->31.220.45.3:22067: i/o timeout
[UAFG3] 09:30:41 VERBOSE: Folder "hrqcl-ad5f9" is now scanning
[UAFG3] 09:30:41 VERBOSE: Folder "hrqcl-ad5f9" is now idle
[UAFG3] 09:30:43 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://62.210.137.230:22067/?id=NHB3KZ6-ENIYGWT-DRB3NNS-SFHFQTY-JQLPUTD-FK6YL2W-WJCRIEG-M7E2HAW&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=tuxli.ch - online.net FR] wan addresses: [relay://62.210.137.230:22067/?id=NHB3KZ6-ENIYGWT-DRB3NNS-SFHFQTY-JQLPUTD-FK6YL2W-WJCRIEG-M7E2HAW&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=tuxli.ch - online.net FR]
[UAFG3] 09:30:50 INFO: Could not connect to relay relay://62.210.137.230:22067/?id=NHB3KZ6-ENIYGWT-DRB3NNS-SFHFQTY-JQLPUTD-FK6YL2W-WJCRIEG-M7E2HAW&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=tuxli.ch - online.net FR: read tcp 192.168.8.144:51488->62.210.137.230:22067: i/o timeout
[UAFG3] 09:30:53 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://138.201.82.134:22067/?id=7JD2UM6-EGA4XRD-RXLBZW7-YBH3D2T-W6YPAPK-V3HTB5J-LEFALSC-TW7TIQH&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=some german] wan addresses: [relay://138.201.82.134:22067/?id=7JD2UM6-EGA4XRD-RXLBZW7-YBH3D2T-W6YPAPK-V3HTB5J-LEFALSC-TW7TIQH&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=some german]
[UAFG3] 09:30:56 VERBOSE: Folder "default" is now scanning
[UAFG3] 09:30:56 VERBOSE: Folder "default" is now idle
[UAFG3] 09:31:00 INFO: Could not connect to relay relay://138.201.82.134:22067/?id=7JD2UM6-EGA4XRD-RXLBZW7-YBH3D2T-W6YPAPK-V3HTB5J-LEFALSC-TW7TIQH&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=some german: read tcp 192.168.8.144:35360->138.201.82.134:22067: i/o timeout
[UAFG3] 09:31:03 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://192.81.221.239:22067/?id=STU3CYX-5ZTD33C-APZSF5Z-T32VEWB-LOXB5ZZ-TYBRUHV-WNW6UOJ-FMOK2AT&pingInterval=45s&networkTimeout=2m0s&sessionLimitBps=500000&globalLimitBps=1048576&statusAddr=:22070&providedBy=Groggy] wan addresses: [relay://192.81.221.239:22067/?id=STU3CYX-5ZTD33C-APZSF5Z-T32VEWB-LOXB5ZZ-TYBRUHV-WNW6UOJ-FMOK2AT&pingInterval=45s&networkTimeout=2m0s&sessionLimitBps=500000&globalLimitBps=1048576&statusAddr=:22070&providedBy=Groggy]
[UAFG3] 09:31:09 INFO: Could not connect to relay relay://192.81.221.239:22067/?id=STU3CYX-5ZTD33C-APZSF5Z-T32VEWB-LOXB5ZZ-TYBRUHV-WNW6UOJ-FMOK2AT&pingInterval=45s&networkTimeout=2m0s&sessionLimitBps=500000&globalLimitBps=1048576&statusAddr=:22070&providedBy=Groggy: read tcp 192.168.8.144:47774->192.81.221.239:22067: read: connection reset by peer
[UAFG3] 09:31:13 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://92.222.95.0:22067/?id=MV6PJJN-6YV3HLR-XC2FMLR-CCWIHMZ-HJ2EIMD-CTF5PK4-RLYCK3S-5YPKIQP&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=@contrib - Strasbourg, FR] wan addresses: [relay://92.222.95.0:22067/?id=MV6PJJN-6YV3HLR-XC2FMLR-CCWIHMZ-HJ2EIMD-CTF5PK4-RLYCK3S-5YPKIQP&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=@contrib - Strasbourg, FR]
[UAFG3] 09:31:19 INFO: Could not connect to relay relay://92.222.95.0:22067/?id=MV6PJJN-6YV3HLR-XC2FMLR-CCWIHMZ-HJ2EIMD-CTF5PK4-RLYCK3S-5YPKIQP&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=@contrib - Strasbourg, FR: read tcp 192.168.8.144:35098->92.222.95.0:22067: i/o timeout
[UAFG3] 09:31:23 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint resolution has changed: lan addresses: [relay://185.81.167.63:22067/?id=VL2I545-5LKYWRI-Q34K2ZN-MGHTYTM-XRBGANJ-RLT2LEN-O77YE7R-WXCQ7AY&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=9000000&statusAddr=185.81.167.63:22070&providedBy=some lithuanian] wan addresses: [relay://185.81.167.63:22067/?id=VL2I545-5LKYWRI-Q34K2ZN-MGHTYTM-XRBGANJ-RLT2LEN-O77YE7R-WXCQ7AY&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=9000000&statusAddr=185.81.167.63:22070&providedBy=some lithuanian]
[UAFG3] 09:31:29 INFO: Joined relay relay://185.81.167.63:22067
[UAFG3] 09:31:34 VERBOSE: Folder "ge3x2-vzytz" is now scanning
[UAFG3] 09:31:34 VERBOSE: Folder "ge3x2-vzytz" is now idle
[UAFG3] 09:31:45 VERBOSE: Folder "hrqcl-ad5f9" is now scanning
[UAFG3] 09:31:45 VERBOSE: Folder "hrqcl-ad5f9" is now idle
[UAFG3] 09:31:55 VERBOSE: Folder "default" is now scanning
[UAFG3] 09:31:55 VERBOSE: Folder "default" is now idle
[UAFG3] 09:32:39 VERBOSE: Folder "hrqcl-ad5f9" is now scanning
[UAFG3] 09:32:39 VERBOSE: Folder "hrqcl-ad5f9" is now idle
[UAFG3] 09:32:48 VERBOSE: Folder "ge3x2-vzytz" is now scanning
[UAFG3] 09:32:48 VERBOSE: Folder "ge3x2-vzytz" is now idle
[UAFG3] 09:32:55 VERBOSE: Folder "default" is now scanning
[UAFG3] 09:32:55 VERBOSE: Folder "default" is now idle
[UAFG3] 09:33:29 VERBOSE: Folder "hrqcl-ad5f9" is now scanning
[UAFG3] 09:33:29 VERBOSE: Folder "hrqcl-ad5f9" is now idle
[UAFG3] 09:33:49 VERBOSE: Folder "ge3x2-vzytz" is now scanning
[UAFG3] 09:33:50 VERBOSE: Folder "ge3x2-vzytz" is now idle
[UAFG3] 09:33:51 VERBOSE: Folder "default" is now scanning
[UAFG3] 09:33:51 VERBOSE: Folder "default" is now idle
[UAFG3] 09:34:21 VERBOSE: Folder "hrqcl-ad5f9" is now scanning
[UAFG3] 09:34:21 VERBOSE: Folder "hrqcl-ad5f9" is now idle
^[[B^[[B^[[B[UAFG3] 09:34:52 VERBOSE: Folder "ge3x2-vzytz" is now scanning
[UAFG3] 09:34:52 VERBOSE: Folder "ge3x2-vzytz" is now idle
[UAFG3] 09:35:02 VERBOSE: Folder "default" is now scanning
[UAFG3] 09:35:02 VERBOSE: Folder "default" is now idle
[UAFG3] 09:35:30 VERBOSE: Folder "hrqcl-ad5f9" is now scanning
[UAFG3] 09:35:30 VERBOSE: Folder "hrqcl-ad5f9" is now idle
[UAFG3] 09:35:45 VERBOSE: Folder "ge3x2-vzytz" is now scanning
[UAFG3] 09:35:45 VERBOSE: Folder "ge3x2-vzytz" is now idle
[UAFG3] 09:35:50 VERBOSE: Folder "default" is now scanning
[UAFG3] 09:35:50 VERBOSE: Folder "default" is now idle
[UAFG3] 09:36:31 VERBOSE: Folder "hrqcl-ad5f9" is now scanning
[UAFG3] 09:36:31 VERBOSE: Folder "hrqcl-ad5f9" is now idle
[UAFG3] 09:36:35 VERBOSE: Folder "ge3x2-vzytz" is now scanning
[UAFG3] 09:36:35 VERBOSE: Folder "ge3x2-vzytz" is now idle
[UAFG3] 09:36:52 VERBOSE: Folder "default" is now scanning
[UAFG3] 09:36:52 VERBOSE: Folder "default" is now idle
