I would like to sync a readonly folder (mounted backups) one way to another pc. I know how to create a one way sync. My issue is about Syncthing needing to create the .stfiles and .stfolders files there, naturally it cant do that since it is read only.
I am trying to sync a folder in /mnt/SYNCFOLDER (Linux)
If possible, temporarily mount the folder as read-write and add .stfolder (it’s a folder, not a file) manually. That’s the only file/folder required for operation. Once that folder exists, the thing can go back to read-only.
Otherwise, if you have a file or folder that you know will always exist, you can manually configure syncthing to use that file/folder. (Set Marker Name for that folder in Syncthing’s advanced (folder) options)
Also, since you’re working with read-only stuff, syncthings folder type send-only makes sense to prevent write errors, if you aren’t using that already.
I think the path is relative to the root of the folder and you do not need to use a slash in the beginning. Example:
Syncthing folder foo located at /home/user/foo
Marker folder/file located at /home/user/foo/bar/marker
Syncthing’s marker name would be bar/marker
(I haven’t actually verified if the above is true, this is only what my software instincts tell me)
PS: It might make sense to choose a folder/file in the root of the syncthing folder (in the example above that would be bar), as I’m not sure if markers in subdirectories are well-supported.
Thanks, I made it work with your guidance. I know some files always exists there like metadata about the backups, so I pointed at that file and now it is scanning.
