So that is the question. Is there trigger or smth?
You would need to listen to the Event API, specifically to the FolderCompletion Event. If the completion is 100, the folder is fully synced.
Is there any simple golang app with event listening example? I found only python.
Yes, see lib/rc and cmd/stevents in the main repo.
