How to reduce CPU usage?
Hello,
How to reduce CPU usage? There is a peak every minute: https://imgur.com/4FfghLl .
I change the Rescan Interval into 300, but how to reduce CPU usage in general?
https://docs.syncthing.net/users/faq.html#why-does-it-use-so-much-cpu
As of 0.14.40 the last part about filesystem notifications is slightly out of date. If you don’t use any of the wrappers, try enabling the advanced folder option ā€œfs notificationsā€ to reduce the scheduled scanning.
Where can I find the options concerning the ā€œfs notificationsā€?
Actions -> Advanced -> the folder -> FS Watcher Enabled
Many thanks. Could you please estimate the benefits / CPU usage reduction in %?
No, sorry, it depends. Try it.
