Hi, I think I have a relatively well defined problem, but despite of similar posts here and a familiar section in the documentation I don’t no how to solve it.
Here is the situation:
- There are two distant Mac computers in the same lan
- On each Mac there a several user accounts
- to make it not too difficult there are no shared folders, each uses only uses their own folder
The problem: On some user accounts, Syncthing does not run. On others I have permissions errors and the sync does not run. Probably the different instances are blocking and interfering each other.
Questions: Is it really true that I have to manually set different port for the accounts?
I think in my config.xml I have a ‘dynamic’ value for the address setting.
Can somebody give me a simple advice or direction about how I can resolve this problems?
Thank you very much Ben
