I’m syncing a Win 7 x64 Pro laptop with a headless Raspberry Pi running gui-less Raspbian.
Evidence collected under st v0.10.29, but problem seems to be still there under v0.10.30.
Folder is configured as master on laptop and rw on pi.
There’s an ro share on the pi, so I can compare with Winmerge on the laptop.
webgui on laptop and pi
UNICORN
DpicturesUp to Date Folder Path D:\Profiles\David\Pictures Global State 31 items, ~20.8 MiB Local State 31 items, ~20.8 MiB Out Of Sync 31 items, ~20.8 MiB
Folder Master Yes Ignore Patterns Yes File Versioning Simple File Versioning Shared With pi Last File Received Override Changes Rescan
pi
DpicturesUp to Date Folder Path /mnt/t/unicorn/pictures/pictures Global State 31 items, ~20.8 MiB Local State 31 items, ~20.8 MiB Rescan Interval 0 s File Versioning Simple File Versioning Shared With UNICORN Last File Received Rescan
Winmerge comparison (csv)
Compare D:\Profiles\David\Pictures with T:\unicorn\pictures\pictures 29/03/2015 09:33:05 Filename,Folder,Comparison result,Left Date,Right Date,Extension .stignore,Text files are different,* 28/03/2015 12:04:49,10/03/2015 22:53:40,stignore CIMG1057.JPG,Binary files are identical,13/11/2013 18:43:00,13/11/2013 18:43:00,JPG CIMG1058.JPG,Binary files are identical,13/11/2013 18:43:00,13/11/2013 18:43:00,JPG CIMG1074.JPG,Binary files are identical,14/11/2013 13:54:00,14/11/2013 13:54:00,JPG CIMG1075.JPG,Binary files are identical,14/11/2013 13:52:00,14/11/2013 13:52:00,JPG maxdesk.ini2,Binary files are identical,26/11/2014 12:57:12,26/11/2014 12:57:12,ini2 meter readings 20141109.jpg,Binary files are identical,26/11/2014 12:50:01,26/11/2014 12:50:01,jpg PP11Thumbs.ptn,Binary files are identical,26/11/2014 12:54:55,26/11/2014 12:54:55,ptn PP11Thumbs.ptn2,Binary files are identical,30/11/2014 12:48:14,30/11/2014 12:48:14,ptn2 Sample Pictures.lnk,Binary files are identical,17/09/2014 11:30:19,17/09/2014 11:30:19,lnk Thumbs.db,Binary files are identical,15/10/2009 19:24:05,15/10/2009 19:24:05,db Vista drives.jpg,Binary files are identical,14/06/2009 23:06:21,14/06/2009 23:06:21,jpg .picasa.ini,Text files are identical,20/11/2013 22:28:55,20/11/2013 22:28:55,ini .stfolder,Text files are identical,06/03/2015 22:42:50,* 07/03/2015 11:41:47,stfolder desktop.ini,Text files are identical,23/05/2014 01:17:51,23/05/2014 01:17:51,ini ControlCenter4,Identical,02/06/2014 08:11:29,* 07/03/2015 11:43:15, Email,ControlCenter4,Identical,02/06/2014 08:11:29,* 07/03/2015 11:45:58, CCE12032013.pdf,ControlCenter4\Email,Binary files are identical,12/03/2013 12:27:03,12/03/2013 12:27:03,pdf CCE21122012_0000.pdf,ControlCenter4\Email,Binary files are identical,21/12/2012 09:54:18,21/12/2012 09:54:18,pdf OCR,ControlCenter4,Identical,02/06/2014 08:11:29,* 07/03/2015 11:45:45, CCO09122012_0000.txt,ControlCenter4\OCR,Text files are identical,09/12/2012 17:15:16,09/12/2012 17:15:16,txt PhotoCapture,ControlCenter4,Identical,14/12/2012 13:03:41,* 07/03/2015 11:43:15, Scan,ControlCenter4,Identical,02/06/2014 08:11:29,* 07/03/2015 11:47:57, CCF14072013.pdf,ControlCenter4\Scan,Binary files are identical,14/07/2013 07:23:30,14/07/2013 07:23:30,pdf CCF14072013_0001.pdf,ControlCenter4\Scan,Binary files are identical,14/07/2013 07:24:22,14/07/2013 07:24:22,pdf CCI08042013.jpg,ControlCenter4\Scan,Binary files are identical,08/04/2013 19:29:55,08/04/2013 19:29:55,jpg CCI19032013.jpg,ControlCenter4\Scan,Binary files are identical,19/03/2013 13:13:44,19/03/2013 13:13:44,jpg Picasa,Identical,02/06/2014 08:11:29,* 07/03/2015 11:43:16, Captured Videos,Picasa,Identical,02/06/2014 08:11:29,* 07/03/2015 11:47:58, .picasa.ini,Picasa\Captured Videos,Text files are identical,21/11/2013 11:27:00,21/11/2013 11:27:00,ini ssl,Left only: D:\Profiles\David\Pictures,* 13/02/2015 00:17:15, ca.crt,ssl,Left only: D:\Profiles\David\Pictures\ssl,* 13/02/2015 00:16:20,crt sub.class1.server.ca.crt,ssl,Left only: D:\Profiles\David\Pictures\ssl,* 13/02/2015 00:17:15,crt
