I have 500k files in set of directories, and the syncthing db has been removed.
The index is being re-created, my problem is it seems like the newestFirst config flag isn’t being honored.
I’m seeing files from July be re-indexed while files from yesterday are still waiting to be indexed.
I had assumed the ‘newestFirst’ config would have caused new files to be re-indexed before older files.
Ideally I’d love for the re-index to simply run in the back-ground, (processing newer files first) and also be able to sync brand new files as they come.
I’m using an old version of syncthing (Forked last Sept), so my issue might have already been resolved.
Thanks for a great product
