I have added Syncthing hassio addon on Home Assistant. And added Syncthing on Open Media Vault. Documentation is add /backup folder, but get folder path error. If I add /config folder, antoher error. Is someone using this and how to add /backup folder from Home Assistant to sync on NAS with Syncthing
Also added HA device in web ui, but then error with folders
2019-04-13 13:12:36: Failed to create folder root directory mkdir /run/s6/services/syncthing/OMVTilen: permission denied
2019-04-13 13:12:36: Error on folder zqkkt-kqkhj: folder path missing
2019-04-13 13:13:01: Failed to create folder root directory mkdir /backup: permission denied
2019-04-13 13:13:01: Error on folder jgosb-ttfk7: folder path missing
You will probably find better help support from the same community that wrote that documentation, as this isn’t a Syncthing problem, but a system setup problem. I have no idea about Home Assistant or Open Media Vault.
Ok
