Hello, I just started using Syncthing to try and sync a folder from my PC to my Android. When trying to sync to my phone, I accidentally hit override, and all of the files I had on my PC folder were deleted. Is there any way I can retrieve these files? I had thousands of images.
Unfortunately not. Only if you enabled versioning on your PC. If you have no Backup, you are out of luck.
