Hi. Global disco disable, and a single st on the lan, no remote node added nor folder, why do I see 2/2 in the GUI ? Is it the 2 instances explained in the FAQ? Please what does the /X include ?
Thanks
Thanks
Iirc local discovery over IPv4 and IPv6 are counted seperately, that’s why you get 2.
In a default config there are eight discovery sources:
You’ve disabled the last six.
