I would like to change the https-cert, so that the GUI uses my letsencrypt-cert.
I backed the originals up and did a sym-link to the letsencrypt-certs, but it did not work. Syncthing didn’t start, claimind it needed to write to the cert-files.
Oh, the error is simply “permission denied”.
Although I provided g+r and g+x for the entire path and g+r and o+r for the files I want syncthing to use.
You should provide the full error line (or even a few lines around that line) as “permission denied” could be coming from many places, not just certs. Anyways, I’d try a+r, just to make sure the user is in the right group etc.
There is nothing special we do to read the cert, and I don’t think we ever write it (unless we can’t read it and we want to generate it, but again, by just seeing “permission denied” I can’t tell you if that is the case)
The surrounding error lines helped, thanks.
It was a path permission problem first, but a error on my part later, linking a wrong certificate file, not matching the key-file.
So, now it works.
Your feedback kept me trying, so thanks.
