I am new to Syncthing, installed it some days ago according to https://apt.syncthing.net/ on a Ubuntu PC without problems. After installation of Syncthing for Android on my phone I wanted to start the configuration on my Ubuntu. But with Firefox and with Falkon/Chromium I get the message “ERR_CONNECTION_REFUSED”/”NS_ERROR_CONNECTION_REFUSED” while trying to GET http://localhost:8384/ - the same using 127.0.0.1 instead of localhost.
I activated HTTP (instead of https) for this url, disabled the addons in Firefox - no change. To test the solution from a similar case in the forum I made a new profile in Firefox - same problem.
My internet connection works.
Directly after the installation of Synthing the GUI came up correctly, in the meantime the PC was rebooted.
lsof: WARNING: can’t stat() fuse.portal file system /run/user/1000/doc
Output information may be incomplete.
lsof: WARNING: can’t stat() fuse.gvfsd-fuse file system /run/user/1000/gvfs
I tested on my Syncthing Device running Ubuntu. In your shoes I’d be sure that Syncthing isn’t running the GUI on TCP/8384 and Syncthing might not be running at all.
First, is Syncthing running? ps -ef | grep syncthing should show two different Syncthing processes.
If the Syncthing GUI is running on another port, lsof | grep syncthing | grep TCP should help.
If Syncthing isn’t running at all, how do you usually start it?
Thanks for the comprehension. Maybe there is an explanation for my mistake: I worked with resilio-sync for some years and resilio-sync starts automatically when the system starts. I had to give it up as it didn’t work any more with an upgraded OS on my RaspPi and I found Syncthing by chance a couple of days ago in search of a possibility to synchronize data between PC and phone. In a 2nd step I will try to make it work on my RaspPi
