I’m getting the following error on startup: globbing: syntax error in pattern, for five files, in a .stversions folder.
Eg: 2016-10-23 10:30:40: globbing: syntax error in pattern for /path/.stversions/directory/.emacs.d/elpa/yasnippet-20160924.2001/snippets/c+±mode/operator[]~[0-9][0-9][0-9][0-9][0-9][0-9][0-9][0-9]-[0-9][0-9][0-9][0-9][0-9][0-9]
Not sure if it’s helpful, but I recently re-installed the OS on the computer where I’m getting this error, then re-installed syncthing and setup the same folders as before.
I don’t need backups of these files, so happy to delete the .stversions folder, if that’s an easy way to resolve this error.
Thank you,
David
— Update 20161023 1440 UTC —
Actually, it looks this issue is generating some serious consequences for me. The files at issue are in my emacs directory, and relate to the yasnippet plugin. Worryingly, its seems like my the majority of my data is now missing from the directory – including my emacs config file.
It causes files which should be cleaned out from .stversions to not be cleaned out. It does not cause files to be randomly deleted from other places though.
No problem – the files are backed up by other means. But still unsure as to what happened this morning – why the files in the primary folder just decided to vanish.
