GetFileInformationByHandle? S :: Incorrect function.
Hello
we use syncthing as work to sync files now my syncthing is showing this error
File system guarding error There was an error for the following folders when you started monitoring changes. It will be retried every minute, so the errors can disappear soon. If they continue, try to fix the underlying problem and ask for help if you can’t. support
My Docs GetFileInformationByHandle? S :: Incorrect function.
is how do we solve this?
OS Windows 10 Build: 1809 OS-Version: 17763.316 Syncthing version: 1.1.0
