Syncthing consumes all my CPU.
I’m using Synctrayzor, but once it goes crazy, I can’t display the content anymore.
I can’t reproduce it at will.
I happens after a while.
A reboot of the application or the PC resolves the problem.
Shutdown Syncthing through Synctrayzor stops the process.
Versions
- Windows
- Synctrayzor : 1.1.28
- Syncthing : v1.18.1
Any idea ?
Regards,
LeNouveau
PS : from Full CPU usage · Issue #7916 · syncthing/syncthing · GitHub
Do you see anything suspicious in the Event Viewer?
You could also upload the logfiles, both from Syncthing itself and SyncTrayzor too.
Also, I suspect its just scanning, and for some reason synctrayzor is not rendering the ui, but you should try accessing via the browser.
imsodin
(Simon)
4
And the log shows the other/remote device uses a very old version that doesn’t support TLS1.3. You need to upgrade Syncthing there to sync.
system
(system)
Closed
5
