For about 2 days, the forum has been loading and working very slowly here. I am not sure whether something is going on with my Internet connection, or the problem is with the forum itself. I have tried restarting the modem and the router, using different Web browsers, etc., but there is no difference. The forum used to load very quickly, but now it seems to take 5+ seconds to process every request.
I have done a few speed tests to check the Internet connection, but they come out normally. Other websites also seem to load as usual.
Has anyone else experienced any slowdowns, or am I the only one?
It feels as usual for me, and I practically live here. Not always ultra snappy but I think that’s just a huge ruby on rails app being a huge ruby on rails app… Certainly no 5s+ wait times.
It used to be snappy, but suddenly became sluggish yesterday, and has stayed this way since then. Especially the very first load may take even 15 seconds or so. After that, it is usable, but still something feels off.
This will probably reveal nothing of much use, but you can do a speedtest to DigitalOceans servers and check if you’re getting acceptable bandwidth and/or latency.
I think this forum (currently) runs in DigitalOcean’s AMS2 data center (at least that’s what a traceroute from my side suggests) and they have a speedtest there:
(For me only the manual test via HTTP test file download worked - compare the speeds you’re getting with the speeds you would expect from a “usual” speedtest. I was getting speeds well exceeding 200 Mbit/s, so the thing seems to be working)
If you’re getting horrible speeds, it’s probably some overloaded transit provider.
The speeds are not great. It is impossible to know what they had been before the slowdown though.
On the other hand, this is the maximum bandwidth of my home Internet connection.
However, the situation seems to have improved a little today. Still not as fast as it used to be, but the forum is loading quicker and responds to requests snappier than yesterday.
Well, I do live on the other side of the globe than Amsterdam, so I am not expecting super fast speeds or anything like that, but this is still way slower than it used to be. The previous rates were from the morning, now in the daytime it is even worse.
I am curious what the problem is though, as both my provider’s speed test and other popular speed tests like https://speedtest.net or https://fast.com do not have any issues. Below is a result of doing a speed test with a server located in Amsterdam (not DigitalOcean though), and everything seems normal here.
This is how it looks like. Also, when pinging forum.syncthing.net, there is no packet loss, so the connection is stable, just very slow.
Windows:
tracert forum.syncthing.net
Tracing route to forum.syncthing.net [37.139.7.17]
over a maximum of 30 hops:
1 2 ms 2 ms 1 ms 10.0.0.1
2 * * * Request timed out.
3 9 ms 10 ms 9 ms X.X.X.X
4 9 ms 10 ms 14 ms X.X.X.X
5 15 ms 10 ms 10 ms X.X.X.X
6 * 13 ms 13 ms X.X.X.X
7 16 ms 15 ms 13 ms X.X.X.X
8 15 ms 15 ms 15 ms X.X.X.X
9 14 ms 13 ms 13 ms X.X.X.X
10 182 ms 176 ms 186 ms X.X.X.X
11 185 ms 181 ms 166 ms X.X.X.X
12 173 ms 167 ms 177 ms sl-mst30-la-.sprintlink.net [144.223.44.41]
13 181 ms 177 ms 181 ms sl-mst31-la-be5.sprintlink.net [144.232.4.129]
14 183 ms 184 ms 183 ms ix-ae-13-0.tcore1.eql-los-angeles.as6453.net [206.82.129.1]
15 347 ms 347 ms 348 ms if-ae-30-2.tcore1.lvw-los-angeles.as6453.net [206.82.129.19]
16 322 ms 326 ms 333 ms if-ae-60-2.tcore1.sv1-santa-clara.as6453.net [63.243.250.54]
17 334 ms 331 ms 312 ms if-ae-0-3.tcore2.sv1-santa-clara.as6453.net [63.243.250.61]
18 318 ms 319 ms 315 ms if-ae-18-2.tcore1.sqn-san-jose.as6453.net [63.243.205.72]
19 329 ms 322 ms 317 ms if-ae-0-2.tcore1.nto-new-york.as6453.net [63.243.128.30]
20 319 ms 320 ms 302 ms if-ae-18-2.tcore2.l78-london.as6453.net [80.231.131.72]
21 312 ms 308 ms 305 ms if-ae-14-2.tcore2.av2-amsterdam.as6453.net [80.231.131.161]
22 319 ms 318 ms 327 ms if-ae-11-2.tcore1.ad1-amsterdam.as6453.net [80.231.152.26]
23 * * * Request timed out.
24 335 ms 333 ms 334 ms 138.197.244.74
25 * * * Request timed out.
26 331 ms 324 ms 321 ms forum.syncthing.net [37.139.7.17]
Trace complete.
Linux (Android):
traceroute forum.syncthing.net
traceroute to forum.syncthing.net(37.139.7.17), 30 hops max, 8 byte packets
1 10.0.0.1 ( 10.0.0.1) 0.638 ms 0.573 ms 2.345 ms
2 * * *
3 X.X.X.X ( X.X.X.X) 14.649 ms 8.913 ms 9.841 ms
4 X.X.X.X ( X.X.X.X) 10.790 ms 10.126 ms 9.023 ms
5 X.X.X.X ( X.X.X.X) 11.326 ms 9.678 ms 11.603 ms
6 * * X.X.X.X ( X.X.X.X) 18.654 ms
7 X.X.X.X ( X.X.X.X) 12.355 ms 20.047 ms 13.382 ms
8 X.X.X.X ( X.X.X.X) 13.939 ms 12.222 ms 44.201 ms
9 X.X.X.X ( X.X.X.X) 16.208 ms 14.887 ms 13.230 ms
10 X.X.X.X ( X.X.X.X) 189.012 ms 186.108 ms 189.083 ms
11 X.X.X.X ( X.X.X.X) 180.441 ms X.X.X.X ( X.X.X.X) 315.724 ms X.X.X.X ( X.X.X.X) 184.310 ms
12 sl-mst30-la-be21.sprintlink.net ( 144.223.44.41) 186.308 ms 182.573 ms 181.882 ms
13 sl-mst31-la-be5.sprintlink.net ( 144.232.4.129) 181.815 ms 185.201 ms 181.979 ms
14 ix-ae-13-0.tcore1.eql-los-angeles.as6453.net ( 206.82.129.1) 180.981 ms 182.126 ms 189.291 ms
15 if-ae-30-2.tcore1.lvw-los-angeles.as6453.net ( 206.82.129.19) 370.892 ms 410.312 ms 407.846 ms
16 if-ae-60-2.tcore1.sv1-santa-clara.as6453.net ( 63.243.250.54) 409.084 ms 430.209 ms 404.578 ms
17 if-ae-0-3.tcore2.sv1-santa-clara.as6453.net ( 63.243.250.61) 322.028 ms 407.691 ms 408.234 ms
18 if-ae-18-2.tcore1.sqn-san-jose.as6453.net ( 63.243.205.72) 408.567 ms 407.116 ms 409.616 ms
19 if-ae-0-2.tcore1.nto-new-york.as6453.net ( 63.243.128.30) 305.024 ms 326.004 ms 388.825 ms
20 if-ae-18-2.tcore2.l78-london.as6453.net ( 80.231.131.72) 320.860 ms 302.035 ms 417.923 ms
21 if-ae-14-2.tcore2.av2-amsterdam.as6453.net ( 80.231.131.161) 407.250 ms 408.474 ms 409.451 ms
22 if-ae-11-2.tcore1.ad1-amsterdam.as6453.net ( 80.231.152.26) 406.471 ms 407.899 ms 406.766 ms
23 * * *
24 138.197.244.74 ( 138.197.244.74) 442.787 ms 385.285 ms 334.668 ms
25 * * *
26 forum.syncthing.net ( 37.139.7.17) 417.073 ms 325.721 ms 369.164 ms
@tomasz86 I don’t know if this applies to you, but I sometimes have to reboot my AVM FritzBox and I don’t know if its the hardware bug of 7490 or my provider but after a re-dialup to DSL it works much faster again then noticable by speed tests.
Routenverfolgung zu forum.syncthing.net [37.139.7.17]
ĂĽber maximal 30 Hops:
1 <1 ms <1 ms <1 ms X.X.X.X
2 1 ms 1 ms <1 ms fritz.box
3 6 ms 5 ms 5 ms srbfra31.as20676.net [213.148.133.235]
4 10 ms 10 ms 9 ms crmdus11-cg-10-0-2-0.as20676.net [87.234.14.167]
5 10 ms 10 ms 9 ms crmdus11-cg-10-0-2-0.as20676.net [87.234.14.167]
6 9 ms 9 ms 9 ms ddf-b2-link.telia.net [213.248.73.1]
7 17 ms 17 ms 16 ms adm-bb4-link.telia.net [62.115.143.162]
8 17 ms 19 ms 17 ms adm-b1-link.telia.net [62.115.137.65]
9 16 ms 16 ms 16 ms digitalocean-ic-335926-adm-b1.c.telia.net [213.248.81.75]
10 * * * ZeitĂĽberschreitung der Anforderung.
11 * * * ZeitĂĽberschreitung der Anforderung.
12 19 ms 17 ms 18 ms forum.syncthing.net [37.139.7.17]
Yeah that really sounds like a transit provider/connection that is choking.
Diagnosing that is a fun thing (not really), you can try and compare traceroutes to providers in a similar region and see what routes give you slow speeds and what routes have good speeds. At some point there should be one transit provider that only appears on the slow routes - that’s the bad player.
Oh and when doing traceroutes, always remember that routing in the www is a mostly asymmetrical thing, e.g upstream route does not equal downstream route. Testing the downstream route requires a traceroute from the other side, which isn’t a trivial thing to do unless you have network access.
You can also try and talk to your local ISP, if you’re lucky they can do something. But I wouldn’t bet on it.
Yes, I highly doubt that they would do anything, as long as their own speed test shows no anomalies. If everything was working slowly, then it would be a different story, but right now this seems to be limited to specific servers/regions. The other websites that I use on a daily basis mostly seem to work as usual.
I have tried rebooting both the modem and the router, and also inspected the configuration, but there has been no change. When it comes to the hardware, everything seems to be working fine.
I just wanted to say that the forum seems to be loading quickly again. I do not now what the problem was (and nothing has changed on my side in between), but it seems to be gone now.
Just for the record, below are the current speed test and tracert.
1 1 ms <1 ms <1 ms 10.0.0.1
3 10 ms 10 ms 8 ms X.X.X.X
4 8 ms 9 ms 11 ms X.X.X.X
5 11 ms 15 ms 10 ms X.X.X.X
6 * 13 ms 14 ms X.X.X.X
7 14 ms 14 ms 13 ms X.X.X.X
8 14 ms 13 ms 15 ms X.X.X.X
9 160 ms 162 ms 153 ms X.X.X.X
10 150 ms 139 ms 147 ms X.X.X.X
11 157 ms 142 ms 174 ms sl-mst30-la-.sprintlink.net [144.223.44.41]
12 147 ms 155 ms 147 ms sl-mst31-la-be5.sprintlink.net [144.232.4.129]
13 171 ms 184 ms 188 ms ix-ae-13-0.tcore1.eql-los-angeles.as6453.net [206.82.129.1]
14 348 ms 318 ms 315 ms if-ae-30-2.tcore1.lvw-los-angeles.as6453.net [206.82.129.19]
15 315 ms 313 ms 288 ms if-ae-60-2.tcore1.sv1-santa-clara.as6453.net [63.243.250.54]
16 290 ms 290 ms 292 ms if-ae-0-2.tcore2.sv1-santa-clara.as6453.net [63.243.251.2]
17 310 ms 297 ms 278 ms if-ae-18-2.tcore1.sqn-san-jose.as6453.net [63.243.205.72]
18 295 ms 287 ms 305 ms if-ae-0-2.tcore1.nto-new-york.as6453.net [63.243.128.30]
19 323 ms 295 ms * if-ae-66-25.tcore2.l78-london.as6453.net [63.243.128.81]
20 299 ms 327 ms 316 ms if-ae-14-2.tcore2.av2-amsterdam.as6453.net [80.231.131.161]
21 323 ms 306 ms 289 ms if-ae-11-2.tcore1.ad1-amsterdam.as6453.net [80.231.152.26]
22 * * * Request timed out.
23 324 ms 306 ms 308 ms 138.197.244.76
24 * * * Request timed out.
25 315 ms 289 ms 308 ms forum.syncthing.net [37.139.7.17]
