Hi
I just discover fsWatcherEnabled option is here since 0.14.40 to replace syncthing-inotify.
I have the latest installed in my 2 linux (I don’t remember how it went here, but whatever I never configured it to make it work, although I was interested). Can I safely uninstall them?
Also, I would like to enable fsWatcherEnabled for a shared folder on the involved nodes, but previously I disabled “Restart On Wakeup” on these nodes. Please do you know if these 2 options altogether on the same node will possibly do errors?
Thank you
[EDIT] There is also a windows in the cluster. Does fsWatcherEnabled also work in Windows ?
You can. Officially the internal watcher is still experimental, but that will be changed soon(ish).
I don’t know for sure, that depends on whether the backend used by the watcher library (notify) preserves watchpoints on sleep-resume - I would assume yes, but I never tested. If you try, please write whether it worked or not.
Yes it does, it works on almost all (maybe all, already forgot) platforms.
