Folder markers are now directories (v0.14.38)
No you can’t, as this is the only way for us to tell when a directory was unmounted for example, and not assume that everything was deleted.
You can configure syncthing to look for some other file to distinguish that, but this would have to be configured on each and every client. This is available in advanced config section for the folder.
We do hide the .stfolder though, so a non-technical user should never see it.
For now I have changed the view in Windows Explorer to not show “hidden items”
It hides all those transparent looking folders and files created for system reasons ( not just syncthing ) I think that is what Simon is saying, and is the easiest way.
But thanks for the for the suggestion by Audrius, I will peek in the advanced config and try hiding the .stfolder outside the syncfolders.
The file / folder must still be inside the syncfolder, not outside, even if you tell syncthing, that it should be .stfolder but bladibla.docx. Then bladibla.docx must exist or syncthing will stop.
fun fact: some android vendors love to delete empty folders. (huawei for example)
thus… this change broke sync on alot android devices.
empty file > empty folder
That happened in September 2017 though, so I guess most people would have adjusted since, somehow?
exactly.
i’m on a Huawei Mate 10 Pro so.. Android 9 sure came with new „features“ one of wich cleans empty directories.
i circumvented this by just placing a empty file inside.
but i doubt 0815 users who got syncthing as recommendation or got help setting it up will be able to figure this out.
in addition:
why does this folder need to be present for a successful sync anyways?
i doubt syncthing is unable to recreate it on demand
It’s a safety check to prevent data loss. Imagine a drive with a syncthing folder getting silently unmounted or getting unreadable somehow - if syncthing rescans data, it might think that the user has deleted all of his files which would then propagate to other devices - resulting in possible data loss. Therefore the .stfolder is always checked for presence, to ensure that the directory is in fact readable and deletes are actual deletes and not errors.
If the folder is not present, syncthing assumes the folder has experienced an error (drive unmounted or similar) and will therefore stop it.
That’s why syncthing will never attempt to re-create the folder on it’s own (at least not without user interaction), as that would break the purpose of it.
I spent hours during this month trying to figure out that the reason why my phone kept losing sync was this. Thanks for the workaround.
I guess putting a .dontdeleteme file in there automatically wouldn’t hurt :wink: seems like this is the best solution to this day.
