Folder isn't making progress 2017
Yes, of course 'cause Windows10 doesn’t let you name a file with a backslash inside.
DEBUG: sendReceiveFolder/qjznm-pqohs@0xc04209eb40 closing Azienditalia Enti locali\2006_3.pdf
DEBUG: temporary: AziendItalia Enti Locali\~syncthing~2006_3.pdf.tmp
There is a case-only difference in the directory name. This is https://github.com/syncthing/syncthing/issues/1787. To fix, rename that directory (and the other one with the same problem) to something completely different, let that sync, rename it back to what you want.
YES!!! It worked: I’m gonna test, but it seems works. At the same time I can assure I’ve renamed the folders before opened this thread, but maybe I haven’t exit from SyncTrayzor before this operation. Ok, thank you for your time and precious work! Thanks, thanks, thanks.
