Integration tests on teamcity fail on the building step since some time, probably since go1.12, as it looks like the gomodule thing is the culprit. The fix should be easy: Checkout at default
instead of go/src/...
to enable gomodules implicitly, just like the regular build job already does. I don’t have permissions to do it, could @calmh or @AudriusButkevicius please take care of it - thanks.
I’ll take a look. I expect I just forgot to convert that build job to module mode.
