Hello people of Syncthing,
i just installed syncthin on my Ubuntu 16.04 LTS. The installation was sucessfull but when i start syncthing the following happens:
alucardo@alucardo-Ubuntu:~$ syncthing -verbose
[monitor] 12:53:53 INFO: Starting syncthing
[MEVOC] 12:53:53 INFO: syncthing v0.14.32 "Dysprosium Dragonfly" (go1.8.3 linux-386)
deb@build.syncthing.net 2017-06-29 13:47:42 UTC [noupgrade]
[MEVOC] 12:53:53 INFO: My ID: MEVOCKY-MVKGMQ6-QY7ILJT-LIXCNZ6-4M3SR37-JWTWQF2-QTKQGII-VYHGJAX
[MEVOC] 12:53:54 INFO: Single thread SHA256 performance is 51 MB/s using crypto/sha256 (33 MB/s using minio/sha256-simd).
[MEVOC] 12:53:55 INFO: Hashing performance with weak hash is 43.14 MB/s
[MEVOC] 12:53:56 INFO: Hashing performance without weak hash is 48.03 MB/s
[MEVOC] 12:53:56 INFO: Weak hash enabled, as it has an acceptable performance impact.
[MEVOC] 12:53:56 VERBOSE: Starting up (/home/alucardo/.config/syncthing)
[MEVOC] 12:53:56 INFO: Ready to synchronize "Default Folder" (default) (readwrite)
[MEVOC] 12:53:56 INFO: Send rate is unlimited, receive rate is unlimited
[MEVOC] 12:53:56 INFO: Rate limits do not apply to LAN connections
[MEVOC] 12:53:56 INFO: Using discovery server https://discovery-v4-2.syncthing.net/v2/?id=DVU36WY-H3LVZHW-E6LLFRE-YAFN5EL-HILWRYP-OC2M47J-Z4PE62Y-ADIBDQC
[MEVOC] 12:53:56 INFO: Using discovery server https://discovery-v4-3.syncthing.net/v2/?id=VK6HNJ3-VVMM66S-HRVWSCR-IXEHL2H-U4AQ4MW-UCPQBWX-J2L2UBK-NVZRDQZ
[MEVOC] 12:53:56 INFO: Using discovery server https://discovery-v4-4.syncthing.net/v2/?id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
[MEVOC] 12:53:56 INFO: Using discovery server https://discovery-v6-2.syncthing.net/v2/?id=DVU36WY-H3LVZHW-E6LLFRE-YAFN5EL-HILWRYP-OC2M47J-Z4PE62Y-ADIBDQC
[MEVOC] 12:53:56 INFO: Using discovery server https://discovery-v6-3.syncthing.net/v2/?id=VK6HNJ3-VVMM66S-HRVWSCR-IXEHL2H-U4AQ4MW-UCPQBWX-J2L2UBK-NVZRDQZ
[MEVOC] 12:53:56 INFO: Using discovery server https://discovery-v6-4.syncthing.net/v2/?id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
[MEVOC] 12:53:56 INFO: TCP listener ([::]:22000) starting
[MEVOC] 12:53:56 VERBOSE: Folder "default" is now scanning
[MEVOC] 12:53:56 INFO: Completed initial scan (rw) of "Default Folder" (default)
[MEVOC] 12:53:56 VERBOSE: Folder "default" is now idle
[MEVOC] 12:53:56 INFO: GUI and API listening on 127.0.0.1:8384
[MEVOC] 12:53:56 INFO: Access the GUI via the following URL: http://127.0.0.1:8384/
[MEVOC] 12:53:56 INFO: Device MEVOCKY-MVKGMQ6-QY7ILJT-LIXCNZ6-4M3SR37-JWTWQF2-QTKQGII-
VYHGJAX is "alucardo-Ubuntu" at [dynamic]
[MEVOC] 12:53:56 VERBOSE: Startup complete
[MEVOC] 12:54:03 INFO: Joined relay relay://212.83.183.57:22067
[MEVOC] 12:54:06 VERBOSE: Listen address dynamic+https://relays.syncthing.net/endpoint
resolution has changed: lan addresses: [relay://212.83.183.57:22067/?id=NZKR4BN-NTT7XCE-
CVNFRVH-6YSYXAY-RI4GC33-QO7UGTC-SBLUGTS-Z3AVQAV&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=2097152&statusAddr=:22070&providedBy=Roberto Santalla @rsroobre] wan addresses: [relay://212.83.183.57:22067/?id=NZKR4BN-NTT7XCE-CVNFRVH-6YSYXAY-RI4GC33-QO7UGTC-SBLUGTS-Z3AVQAV&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=2097152&statusAddr=:22070&providedBy=Roberto Santalla @rsroobre]
[MEVOC] 12:54:07 INFO: Detected 3 NAT devices
[MEVOC] 12:55:05 VERBOSE: Folder "default" is now scanning
[MEVOC] 12:55:05 VERBOSE: Folder "default" is now idle
[MEVOC] 12:56:08 VERBOSE: Folder "default" is now scanning
[MEVOC] 12:56:08 VERBOSE: Folder "default" is now idle
[MEVOC] 12:57:14 VERBOSE: Folder "default" is now scanning
[MEVOC] 12:57:14 VERBOSE: Folder "default" is now idle
[MEVOC] 12:58:02 VERBOSE: Folder "default" is now scanning
[MEVOC] 12:58:02 VERBOSE: Folder "default" is now idle
[MEVOC] 12:59:09 VERBOSE: Folder "default" is now scanning
[MEVOC] 12:59:09 VERBOSE: Folder "default" is now idle
[MEVOC] 13:00:19 VERBOSE: Folder "default" is now scanning
[MEVOC] 13:00:19 VERBOSE: Folder "default" is now idle
[MEVOC] 13:01:13 VERBOSE: Folder "default" is now scanning
[MEVOC] 13:01:13 VERBOSE: Folder "default" is now idle
[MEVOC] 13:02:05 VERBOSE: Folder "default" is now scanning
[MEVOC] 13:02:05 VERBOSE: Folder "default" is now idle
[MEVOC] 13:03:19 VERBOSE: Folder "default" is now scanning
[MEVOC] 13:03:19 VERBOSE: Folder "default" is now idle
I reinstalled syncthing but the same result no matter how long i let it go.
Thanks for your helpfull post.
