Hello. When mirroring does not update files from 10Gb or more. 6gb is normal. If on the receiving side delete the old file and temporary, then mirror normally. Conclusion: only new files are mirrored, existing files larger than 10Gb are not updated.
Mirroring between Debian and Windows. Versions latest total.
Hi. 4GB memory. Temporarily decided to delete old versions of files on the second side. After removing the old versions, the new versions of the files loaded normally. The update does not pass. The problem remained.
It might not be fully indexing the file. I’m able to pull down 400Gb+ server backup files off remote servers. It does take a long time before they start, but they do get there…
I tend to do these as a monthly offsite (as a 3rd backup for my lab testing for updates etc)
