Delete the synching folder and / root /. Config/ config.xml Then re install. The binary is then started without any parameters. It is invalid to modify the user name, password and encrypted transmission mode, and it is always prompted that the default transmission mode has not been modified.
Sorry, but no I don’t understand the question.
I think you understand! After re installation, the use HTTPS for GUI option is selected and then re entered. It is still not selected.
Check the logs, perhaps the config directory is not writable, or not writable by the current user.
Also check browser developer tools.
Thank you. Your suggestions will be very helpful
