Extend current filename-only to a longer path in Out Of Sync
Hello! :slight_smile:
I came across a little problem when syncing which is this:
When files are Out Of Sync you can view which of the files that are affected. The problem arises for me when I have several folders with identical or similar filenames. It is then hard to identify which files are affected.
I suggest either adding a longer path for these files or perhaps include a tooltip via(html title?) which displays a longer path for all the respective files.
I’m using v0.11.24 on Mac OS X (64 bit) :sunny:
You might want to add this as to the issue tracker.
I guess I have seen tooltips like that already… Just can’t provoke the situation right now.
here it is on a Linux System:
Oh well then :smiley: Sloppy me!
Like this?
