hi
I am trying to synchronize two windows PC. Using 0.14.26 syncthing and 0.8.5 syncthing-inotify.
It happen before so I did uninstall syncthing {deleting it and configs} then install from scratch and configure. It was working OK for while.
Problem:
- creating new file on PC #1
- I can see log message in inotify window on PC #1
- PC #2 saying in webgui, that that file is last update BUT file is not on PC #2 !!!
- synchronize in opposite direction is same problem.
- webgui on both PC saying that folder is “up to date” and that other PC is “up to date” too
what should I check? what can be problem?
thank you
