Now here’s the thing, i have a particular sync that deals with large files that i can only allow over wifi while all the rest are fine and i can have and kinda NEED over data, any way to selectively change the data settings for these syncs? I tried the web gui from the app but i couldnt find anything of use. Any help would be appreciated
This is impossible unless you write your own scripts and control Syncthing through the REST API. Alternatively, Syncthing-Fork does offer more control over sync conditions on a per folder level.
if you like hacks you could run 2 Syncthing instances: “device” A shares large file folders and “device” B shares small file folders
On phone you add “device” A with WLAN address and B with WLAN address and also external IP/port forwarding. Then all you need to do is select folders from each device.
At home phone will find both A and B with WLAN and on the road the phone will only connect to B
