I’ve done the mistake in upgrading my DSM from 6 to 7 without realizing that Syncthing Kastelo is not supported.
I’ve now re-installed Syncthing community version and i can’t figure out how to restore my configuration. Devices and locations haven’t changed , only the OS and Syncthing version.
Old configuration files are in /volume1/syncthing-data/ , where can i copy the contents of this folder to restore my previous configuration/files ?
Wasn’t sure how to edit my previous post but with the help of an ungodly amount of googling , i was able to restore my previous configuration. Topic can be locked.
So after i found myself with DSM7 and the new Syncthing i wasn’t sure where the new configuration files were so i had to run htop in ssh(putty) to see where is Syncthing running from, which took me to the folder @appdata.
Then i stopped Syncthing , i used chown to change the permissions of the files (to admin) , deleted them and then used WinSCP to browse to the path and paste my old configuration back in there.
Then i used SSH to chown them back to how they were in the first place. chown -hR sc-syncthing syncthing.
