merlinuwe
(merlinuwe)
May 21, 2015, 5:22pm
#1
I tried to let discosrv (discosrv-freebsd-amd64.tar.gz) run on my FreeNAS 64bit system, but it hangs: sometimes I get no respond from the shell, sometimes I get:
freenas# /mnt/NAS1GB/syncthing/discosrv -db-dir="/mnt/NAS1GB/syncthing/discosrv-db" &
[1] 3513
freenas# 2015/05/21 19:09:51 open /var/discosrv/stats: no such file or directory
And very rarely I get a normal response.
Rebooting does not solve the problem.
I tried to call:
./discosrv
and
I downloaded it from here (#1077 ):
http://build.syncthing.net/job/discosrv/
(Some newer downloads have a red marble.)
The content of the file /mnt/NAS1GB/syncthing/discosrv-db/LOG:
=============== May 21, 2015 (CEST) ===============
19:11:28.016891 log@legend F·NumFile S·FileSize N·Entry C·BadEntry B·BadBlock Ke·KeyError D·DroppedEntry L·Level Q·SeqNum T·TimeElapsed
19:11:28.017603 db@open opening
19:11:28.020986 db@janitor F·2 G·0
19:11:28.021052 db@open done T·3.421664ms
Any idea?
Greetings,
merlinuwe
mkdir -p /var/discosrv/stats
is the any output to stdout?
merlinuwe
(merlinuwe)
May 21, 2015, 5:31pm
#3
It is not possible to build this directory, because it is a FreeNAS system which boots from usb-stick and the system is write protected.
The only output is
edit:
and
2015/05/21 19:33:06 open /var/discosrv/stats: no such file or directory
… but I have called the following line, so this “cannot be”:
calmh
(Jakob Borg)
May 21, 2015, 6:21pm
#4
The stats file is a separate flag:
discosrv -db-dir /tmp/foo -stats-file /tmp/foo-stats
No output is normal; you’ll only get output in case of errors, and in the stats file every five minutes or so.
merlinuwe
(merlinuwe)
May 21, 2015, 7:03pm
#5
I tried the following:
/mnt/NAS1GB/syncthing/discosrv -db-dir="/mnt/NAS1GB/syncthing/discosrv-db" -stats-file /mnt/NAS1GB/syncthing/foo-stats
After 10-15 minutes, there occures this output in the file “foo-stats”:
1432234800 Kept:2 Deleted:0 Took:0.0257s
Does this help to localize the issue?
calmh
(Jakob Borg)
May 21, 2015, 7:32pm
#6
That looks like it’s working perfectly. Two announces are in the database. What’s the actual problem?
