Folder HHG shared on 3 devices, all.at v0.11.2, windows devices SyncTrayzor 1.0.15, all on lan
- pauline win7 master
- pi rraspbian rw
- unicorn rw
Audio file x.mp3 on all devices. Import x.mp3 into Audacity on Unicorn Use Audacity’s normalise function Save Audacity project in folder. This save creates x.aup and a directory x_data containing a folder which contains 1 or more other folders which contain *.au files. Export x.mp3 (replace), x.m4a and x.ogg (new) Exit Audacity
All files synced to pi. All as expected so far
Delete x.aup and directory x_data.
I’m expecting that the Audacity file and directory will be moved to .stversions
On pi I get
May 07 14:55:42 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d03”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d03: directory not empty May 07 14:55:42 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d02”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d02: directory not empty May 07 14:55:42 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00: directory not empty May 07 14:55:42 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data: directory not empty May 07 14:55:43 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d03”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d03: directory not empty May 07 14:55:43 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d02”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d02: directory not empty May 07 14:55:43 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00: directory not empty May 07 14:55:43 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data: directory not empty May 07 14:55:43 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d03”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d03: directory not empty May 07 14:55:43 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d02”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d02: directory not empty May 07 14:55:43 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00: directory not empty May 07 14:55:43 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data: directory not empty May 07 14:55:44 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d03”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d03: directory not empty May 07 14:55:44 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d02”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d02: directory not empty May 07 14:55:44 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00: directory not empty May 07 14:55:44 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data: directory not empty May 07 14:55:44 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d03”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d03: directory not empty May 07 14:55:44 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d02”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d02: directory not empty May 07 14:55:44 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00: directory not empty May 07 14:55:44 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data: directory not empty May 07 14:55:45 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d03”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d03: directory not empty May 07 14:55:45 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d02”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d02: directory not empty May 07 14:55:45 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00: directory not empty May 07 14:55:45 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data: directory not empty May 07 14:55:45 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d03”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d03: directory not empty May 07 14:55:45 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d02”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d02: directory not empty May 07 14:55:45 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00: directory not empty May 07 14:55:45 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data: directory not empty May 07 14:55:46 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d03”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d03: directory not empty May 07 14:55:46 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d02”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d02: directory not empty May 07 14:55:46 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00: directory not empty May 07 14:55:46 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data: directory not empty May 07 14:55:46 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d03”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d03: directory not empty May 07 14:55:46 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d02”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d02: directory not empty May 07 14:55:46 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00: directory not empty May 07 14:55:46 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data: directory not empty May 07 14:55:47 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d03”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d03: directory not empty May 07 14:55:47 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d02”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d02: directory not empty May 07 14:55:47 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00: directory not empty May 07 14:55:47 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data: directory not empty May 07 14:55:47 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d03”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d03: directory not empty May 07 14:55:47 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00/d02”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00/d02: directory not empty May 07 14:55:47 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data/e00”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data/e00: directory not empty May 07 14:55:47 pi syncthing[279]: [POLZA] INFO: Puller (folder “Phhg”, dir “x_data”): delete: remove /mnt/t/sync/paulinepc/hhg/x_data: directory not empty May 07 14:55:47 pi syncthing[279]: [POLZA] WARNING: Folder “Phhg” isn’t making progress - check logs for possible root cause. Pausing puller for 1m0s.
The directories aren’t empty - 11 *.au files ( out of 2036) are in their original place and not in .stversions.
On unicorn I get
[JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003859.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002395.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003e3a.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e000287c.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002e7f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00025bf.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002f09.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e00034d4.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003a3f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002574.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00026e6.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002395.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003859.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003a3f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e000287c.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002e7f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002574.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00025bf.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e00034d4.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00026e6.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003e3a.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002f09.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003e3a.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00025bf.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e000287c.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002f09.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003859.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003a3f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e00034d4.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002395.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002e7f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00026e6.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002574.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e00034d4.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002574.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002f09.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003a3f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00026e6.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003859.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002395.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00025bf.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e000287c.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002e7f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003e3a.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003859.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003a3f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00025bf.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002f09.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002395.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003e3a.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e000287c.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002574.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00026e6.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e00034d4.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002e7f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00026e6.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e00034d4.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002e7f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003859.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002574.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00025bf.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002f09.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003a3f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002395.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e000287c.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003e3a.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002f09.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00026e6.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e00034d4.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003859.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003a3f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e000287c.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002e7f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003e3a.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00025bf.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002395.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002574.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002574.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00025bf.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003859.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002e7f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003e3a.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002395.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003a3f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00026e6.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e00034d4.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002f09.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e000287c.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e00034d4.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00025bf.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002395.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002574.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003859.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002e7f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e000287c.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002f09.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003e3a.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003a3f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00026e6.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e00034d4.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00026e6.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003a3f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e000287c.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002574.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00025bf.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002395.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003859.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003e3a.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002f09.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002e7f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002395.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e000287c.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002f09.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002e7f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003859.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e0002574.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003e3a.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e00034d4.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00025bf.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d03\e0003a3f.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d03: The system cannot find the path specified. [JFW3X] 15:10:47 INFO: Puller (folder “Phhg”, file “x_data\e00\d02\e00026e6.au”): dst stat dir: GetFileAttributesEx \?\d:\hhg\x_data\e00\d02: The system cannot find the path specified. [JFW3X] 15:10:47 WARNING: Folder “Phhg” isn’t making progress - check logs for possible root cause. Pausing puller for 1m0s.
HELP!
