So, I have a device that according to my local device is stuck at “Syncing (95%, 0 B)”. The thing is, accessing the control panel of said device yields no such errors, it seems to be working perfectly.
Changes to the synced folder (on my local device) are all registered correctly and mirrored on the device in question. Even the 9 files that my local device reports aren’t synced (deleted) are.
The files in question are 9 seemingly random files from a subfolder which ancestor I deleted. The ancestor contained a lot of files/folders of varying depth. - All of which have been deleted and synchronized properly.
Yes. But not only that - it is in sync. The folder that was deleted on the local device has been deleted on the synchronized device. None of the files that the local device reports to be out of sync, is in fact in sync (deleted).
curl -H "X-API-KEY: *yourApiKey*" -X GET 'localhost:8384/rest/db/file?folder=*yourFolderID*&file=*outOfSyncPath*'
after replacing the parts between * with the appropriate content from both sides. You can get the api key from the settings dialog in the UI or the config file.
