I have one macbook pro and one workstation (opensuse Leap 42.1).
These two device could not see each other in the same network, which
has firewall configured.
In the macbook pro I installed the syncthing via brew, in opensuse I downloaded and used the binary file of 0.14.8 (the repository provides the old 0.12). In both setting, the NAT, local/global discovery and relaying are
enabled.
For the workstation it has a static ip, and I modified the address according
to the discussion in the forum. It did not work.
The firewall block many ports, so I am not sure 22000 is blocked as well.
How could I figure this out?
What diagnosis should I do? Sorry I am a newbie in linux.
@AudriusButkevicius There are http, https and ftp proxy set for all internet connection. I guess this might lead to the disconnected service. In the introduction syncthing
seems to be able to go through proxy, how to manage it?
In the command line, should I write this?:
export all_proxy=socks5://10.20.30.40:5060
is “10.20.30.40:5060” universal or I should figure out for my setting?
